04-03-2005, 10:31 AM | #1 |
K24 Not Starting
Okay having some problems. Changed the plugs wires, and battery. Car doesn't start. It tries, but it shakes and doesn't start. Almost turns but nothing. Also my radiator has a crack in it. Would this cause a vacum problem making it not able to start? My friend was saying it kinda sounded like my fuel filter was clogged. Does anybody have any insite about this problem/?? Thanks
04-03-2005, 04:02 PM | #2 |
change the fuel filter. Could be the fuel pump. Make sure that its priming correctly. If you cant smell gas then theres most likely a problem. Then theres the starter. You can take that in to get tested as well. Ignition coils. Theres alot of stuff to check.
04-03-2005, 06:05 PM | #3 |
Sounds like you guys are just pulling shit out of the air. Take your car to a mechanic.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
04-04-2005, 03:16 AM | #4 | |
You'll need to explain a bit more before we can even figure out what may be the cause of your starting problems. ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies.... |
04-04-2005, 06:16 AM | #5 |
i have a 1993 240 with a KA. im going through the same problem, but i have dont have a crack in my radiator. besides that, check if you are getting spark, check if your fuel pump works...easiest way is just to listen to it when your key is in the start position.
you can also know if it is something electrical because if it is, theres a high possibility that your ecu would be shorted out, therefore you wont have a check engine light. this is everything i checked: 1. starter 2. ignition coil 3. relays 4. grounds 5. fuses 6. distributor along with the cap and rotor 7. fuel pump 8. spark plug 9. spark wires 10. battery 11. gas (trust me, some people forget) 12. check the wire harness in the left front fender..make sure theres no damage. 13. evreything else you can think of. these are just the basic things.... if you are totally not sure or have no time, take it to a mechanic. if you know what youre doing and have a shit load of time...then start with what costs the less first and pray. it turns out that my car has a shorted relay, and my wire harness in the left fender (that hold ignition wires and shit) was also fuckin up my ecu. finding a good ecu is a bitch... hope this helps a little. |
04-04-2005, 08:23 AM | #6 |
It's a 1993 240sx with a ka24de, it will start now, it just takes a few good tries, while holding down the accelerator. That is if i put pressure on the cracked radiator. Once it starts and idles, it's fine until it heats up. Then once warm and the radiator starts steaming a little the idle pulsates up and down. Any clue, guy at advanced auto said it could be due to the drop in pressure in my collant system. This was happening even before i touched the car. So i did the basics, plugs and wires, battery and a fuel filter. Gonna change the oil probably tuesday. But Need any more info before you start giving me some info?? Thanks
04-04-2005, 01:10 PM | #7 |
change the rad change the thermo change the water.
if you have a leak in the rad dont bother with oil fix the rad first. If theres still a bad idle then maf and 02 sensor could be your culprit. |
04-05-2005, 11:53 PM | #8 |
This morning i started it up and it started on the first try, cept i had to keep it cranking for about 30 seconds, and today was kinda hot. Any clue why htis would be? O also beside the radiator being cracked, it appears my waterpump is leaking. Would this be a problem why the car is having a hard time starting?? All info is greatly appreciated. Thanksf
04-07-2005, 06:15 PM | #9 |
change all of the stuff to do with the coolant system. Thats why its running warm the water pump isnt doing its job. Buy a oem one because i have heard of all the autoparts place leaking.
The only time i have had a problem with cranking was that my fuel pump was going.... also could be a wire loose on the ignition. Check to see if the fuel pump is priming correctly and that all the wires going into the ignition are good. Then check the starter. You can even take out the starter and take it to a autoparts store to make sure it functions correctly. |
