03-04-2006, 10:49 PM | #61 | |
03-05-2006, 03:35 PM | #62 |
I'm using 93oct pump gas... I'm not going to make big changes at first, because I'm trying to help out the average 240sx owner by charting the gains made by readily available parts. Most guys aren't going to go drop $1400 on an AEM when they only have exhaust mods.
When I'm done with the simple stuff I'll go all out and start tweaking things. Who knows, maybe I'll actually hit the elusive 200whp mark. |
03-05-2006, 03:51 PM | #63 |
Sounds good, I was just asking what octane you were using because (Scott)in geocities had a JWT tune, crank pulley, header and Greddy 3" exhaust. With no cams he pulled 169WHP, and 170ft/lb.s of torque using 104 octane to prevent any knock that would decrease the ignition timing. He also used the stock intake so those were pretty good numbers.
If the knock sensor is disabled (closed loop) those same numbers could be achieved on lower octanes, after all the KA's CR is under 9.6:1, I seriously doubt detonation would ocurr with that CR and 96octane. Then there is no interferance with the knock sensor at higher RPMs possibly allowing to achieve those same HP numbers. Of course with some fine tuning of the ignition and fuel maps....... I defenitely wouldn't risk disabling open loop if infact I was running higher CR's that would cause detonation, so in this instance closed loop would not be disabled..... Who said anything about tuning with an AEM $1400? Biki Roms are $300 and follow nissan ECCS developement. AEM EMS is reversed engineering that can sometimes be counterproductive in making BIG HP numbers, IMO many standalones are outdated and expensive once you've been taught ROM emulation, it's just more cost effective, and it SHOULD be affordable for those that just do exhaust tuning, or basic bolt ons, JWT blows. Last edited by BigVinnie; 03-05-2006 at 06:53 PM.. |
03-05-2006, 10:48 PM | #64 |
i've got a 3" resonated testpipe from my s13 i'm not using, a little scraped on the bottom but will trade for cheap dyno time to see what my almost stock ka is putting down.
03-05-2006, 11:19 PM | #65 |
bigvinnie - interesting numbers... but you really can't compare numbers from one dyno to another, or really even one car to another. That dynosheet doesn't prove anything without a baseline on his car for comparison to see how much he actually gained over stock.
If bikiROM can be used to tune and it's cheaper, then good deal. What I have to tune with is an AEM EMS. Most guys will be using an SAFC, JWT ecu, or emanage to tune an S14 KA24de. What I said still stands - I'm doing some basic tuning here to begin with. After that, I'll do what I feel neccessary to make the power that I'm shooting for. I'll post the tuned dyno runs tomorrow. |
03-05-2006, 11:28 PM | #66 | ||
03-06-2006, 11:14 AM | #67 |
Looking foward to see the dyno for your cams swap. I currently have the 248/248 setup. I want to try 248/232 and 248/240 this summer. Not sure which one is best but there is only one way to be sure. Keep on posting your dyno sheets and updates. References is always a good thing.
03-06-2006, 12:44 PM | #68 |
Sorry about asking for rep guys. I'm on several different boards, some of which asking for rep is a common occurance, I forgot about Zilvia's policy.
Cam dyno should be up shortly. |
03-06-2006, 02:28 PM | #69 |
I wonder when people will understand that BACKPRESSURE doesnt help with low end torque. exhaust gas scavenging caused by smaller diameter exhaust tubular headers do, which helps with scavenging at low RPMs, which helps with low end torque. it is mostly dependant on the header/head design more than anything, and not much to do with the exhaust.
high performance driveway photography zenki s14---v8 fc rx7 my crappy flickr page (drift cars whoo) |
03-06-2006, 05:15 PM | #70 | |
Back pressure does play a small roll in how pulses are delivered to each cylinder, but then again we are talking under 2% is needed to regulate a smooth positive pulse. I disagree with the use of a 4-1 on the KA after all it isn't a high rever that would utilize power to well in high RPM's (over 6500RPM). I have found 4-2-1 headers to work the best on the KA since it utilizes the majority of it's power early. |
03-06-2006, 10:32 PM | #74 |
The tuning throws a variable in there... many (including myself) dont bother with tuning until most of the bolt ons have been done in N/A form. So your tuning will throw off the curve, would it be possible to do a run with the cams using your tuning and another run with the OE ECU plugged in?
I plan to go MegaSquirt with a MAP sensor soon but its not a top priority as I'd like the suspension to be tightened up a bit first. ~Kris
It never got fast enough for me. -Hunter S. Thompson |
03-07-2006, 06:02 PM | #77 | |
AFC #1
03-27-2006, 11:54 PM | #78 |
Sorry that I left this thread for so long. Here's the status:
The header was packaged wrong, it's for an sohc, which explains why it wouldn't ever fit right. I still would not reccomend it, it's pretty much junk. My car is down, so I haven't driven it in almost 2 weeks, just sorting through a lot of stuff that I've been meaning to maintain or fix over the last 9 months. I have another vehicle to drive, so I just haven't spent any time on it. Lastly, I bought an series 1 RB25det that I'm freshening up to drop in. Yeah, I decided to make the plunge, possibly going for 400whp off the bat with a GT30r. Sorry for everyone that was looking for more N/A KA dynos. If anyone lives around Carrollton and wants to dyno their car before/after with n/a mods to continue this thread or one like it, pm me and we might be able to work something out as far as free dyno time goes in order to help out our fellow 240 enthusiasts that are looking for cheap power. |
03-28-2006, 07:34 AM | #80 | |
UUUUMMMM SOHC ports are completely different, they don't even bolt up, or are interchangeable. |
03-28-2006, 04:56 PM | #81 |
You are entitled to your opinion. Johnny5 has seen my car and lives near me... pm him and ask him if I'm lying.
As far as the dohc/sohc thing goes, I have no idea, since I have never worked with sohc ka's at all, period. I'm going off the part number that was on the outer box, vs the part number on the tag inside... outer said nothing, inner said sohc. It's possible that their whole labeling system is screwed up. |
03-28-2006, 06:04 PM | #83 | |
there is no fitment problem for putting an s13 header on s14, the EGR stuff is at the wrong angles, but it will bolt to the head fine and clear steering components. I did it.
using hotshot headers.
03-29-2006, 01:42 PM | #84 |
I have no idea what the header is or why it didn't fit at this point.
It's possible that it is an S13 Dohc header, all I know it that it fit everywhere except the steering column clearance. I banged it with a hammer a little and thought that would do the trick, but I came to find that on right hand cornering the motor would move and it would bind... causing a potentially dangerous situation. It made power, it just wasn't worth it. The paint immediately burnt off, making the header look like it has skin cancer too. |
04-04-2006, 10:25 PM | #85 |
This was a good thread, I learned a lot! Thanks to anyotherone for his detailed efforts!
The only thing I would add is although a 3" exhaust clearly is superior to a 2.5", has anyone taken the weight difference into account? A 2.5" pipe has a circumference of 7.85" and a 3.0" is 9.42". The difference is about 1.5". Multiply that by the length of the pipe, for example 118", and by thickness, 1/8" gives you 22.1 cubic inches Stainless steel is 474.4 lbs/cu ft or .2745 lbs/cu in. ok, so that's 6 lbs of extra weight.. not much to make a difference. |
04-28-2006, 01:17 PM | #88 |
Sorry, I've actually pretty much abandoned my n/a KA power search. Too busy here at the shop to get on the dyno, lot's of personal stuff taking up my free time.
I actually have an RB25det now that I'm prepping for install, hopefully within the next couple of weeks. Should be fun, I'm planning on making 400rwhp with a GT35r and other mods on lowish boost. |
04-28-2006, 01:33 PM | #89 |
well i made 160hp and 147tq on a stock ka with intake and ehxuast. it was a 91ka with 200K+ miles. nuff said =D
This box is 400x200: Please do not put your sig pic back if it exceeds this. -Moderation |
04-28-2006, 01:37 PM | #90 | |
1997 240sx ------------------------- 1993 300zx TT |
