04-20-2015, 02:37 PM | #1 |
Running rich?
I have a manual swapped(by previous owner) 91 ka24de and I noticed it's using a lot of gas sometimes and I always shift around 2.5k-3k (breaking in new oem clutch I put in). When I bought this car about 6-8 months ago I replaced fuel filter, oil/filter, new aem cone filter(already had aem intake), new o2 sensor (old one was very black), and checked spark plugs and they seem to be in normal wear condition not black or anything like that. I checked my new O2 sensor and it's very black just like the old one. Engine idles around 750-800 after warmed up and sometimes I see it around 800-850 when I am at a light or stop sign. Sometimes I have start up problems, for example I go for a short drive and go into a store for like 5 mins, come back and try to start my car but it dies within 2-3 secs unless I apply some gas.. Sometimes I hear backfire from exhaust. Anyone have an idea what it might be?
04-20-2015, 05:50 PM | #3 |
Well the black on the O2 sensor is normal since its exposed to the exhaust gases..since you have a ka24de I would say do a tune up (plugs, wires, cap and rotor) after doing so check your ignition timing with a timing light..then while your at it buy a bottle of maf cleaner and clean your Maf. I'm sure those will fix your issue.and let's just say they don't, at least you didn't waste money on things you should do anyways as maintenance.
Instagram username:angelmkiv |
04-21-2015, 02:27 PM | #5 |
What does your exhaust tips look like? When I had a leaky injector my car did exactly that and my exhaust tips were very black and sutty.
http://zilvia.net/f/showthread.php?t=558989 ^here is my thread about it |
04-21-2015, 05:52 PM | #6 |
Well I just have worst luck ever... I took out all of my injectors one by one to check for any cracks but once I was all done and have everything reconnected the way it was before it doesn't even want to run anymore. Like it's getting over flooded now because my spark plugs are black as hell now to.
Supposedly fuel injectors supposed to "pop" back into place? I apply so much damn pressure they won't pop in. So I am thinking that's why I am flooding the engine now. Last edited by zfortune; 04-21-2015 at 06:47 PM.. |
04-22-2015, 01:03 PM | #10 |
Recommended fuel injectors to buy? I know 270cc but brand and what not. I just looked over my injectors again I noticed 2 of the 4 haves a crack above the bigger o-ring seal. So I am sure it'll leak through there to. I am going to check the oil today to. Also going to buy new spark plugs.
04-22-2015, 01:38 PM | #11 | |
04-22-2015, 01:48 PM | #12 | |
Edit: Sooo much gas in the oil, gotta give myself a big clap of doing it wrong..... Hopefully I didn't fuck up the engine. Edit: New plugs, oil/filter, new fuel injectors and car is running again! Still needs to burn the extra crap though. Feels like it's running a bit better, will update tomorrow since I'll be driving quite a bit. Last edited by zfortune; 04-22-2015 at 09:15 PM.. |
05-13-2015, 04:06 PM | #13 |
Also replaced cap and rotor, adjusted tps to .5v closed, wot was at 4.18v but now I am getting code 13, 43, and of course still using a lot of gas. Getting 15-20mpg in city. Still shifting around 2.5k-3k.
I am pretty sure my TPS is still the auto version since the car was auto from factory but I am not sure if that'll make a huge difference. |
05-13-2015, 04:51 PM | #14 |
The best way to repace o rings is buy them from nappa or nissan only.
You also need to cover them with vasolien befor you put them in otherwise you will damage the o ring when you put them in. Slight push and twist and they should pop right in. Don't be light on the vasolien. |
05-13-2015, 11:01 PM | #17 |
yeah I am buying the coolant temp sensor tomorrow and put it in. I replaced knock sensor a month ago because it had cracks all around it and I also replaced the little harness connector with it since it was cut up by previous owner.
05-15-2015, 05:30 PM | #18 |
Installed new coolant temp sensor today and cleared codes on ecu. I'll see how it goes this week(end) but even when i drove it for about 10m today the ecu still throws code 34 knock sensor. I bought the knock sensor from frsport. Been throwing it since i replaced it. Oh yeah the new sub harness fot the knock sensor only had one wire running to the knovk sensor, like the old one. Is that right? I bought it from wiring specialist so i would think it would be right
right Last edited by zfortune; 05-15-2015 at 06:37 PM.. |
05-21-2015, 02:40 PM | #20 |
Everything seems fine but this damn Code 34 knock sensor keeps coming back!!!! Went through 3 sensors and 2 subharness but it just wants to keep coming back.
I did a test, unplug tps turn on car and let it idle for like 5mins, turn off car, check ecu for codes, i got 55. I did this test again and got 55. If i plug tps back in and let engine idle, i would get code 34 instantly. So i guess tps might be out of spec? .45 closed, 4.21 fully open. Last edited by zfortune; 05-21-2015 at 04:07 PM.. |
05-21-2015, 07:16 PM | #21 | |
You should get a mafs code. Sent from a Highly Boosted Note 4!!!
05-21-2015, 07:29 PM | #22 |
Got a new auto digital meter with the auto functions and tested the tps itself and found blank spot at 5k-6.5k ohms. Closed is at .975 ohms and fully open at 8.15. So i am just going to replace it.
05-26-2015, 06:27 PM | #23 | |
Replaced Tps set to .45. Already put like 30-40ish miles on it the past 2 days and no codes come up but today after work I check the ecu and the damn code 34 again.... Could a/f ratio be off to causing knock sensor to come up?? Like to much gas or to little or maybe even air? |
05-26-2015, 08:42 PM | #24 |
The code you are getting is a code for a faulty sensor, circuit or wiring. That's what cause the ecu to throw the code, but the symptoms can vary. Mainly because people tend to drive with a knock sensor code.
Now if you are truly knocking/pinging? Then switching to higher octane gas might remedy that issue. Have you checked the health of your engine, vacuum, compression, leak down or even plugs? Sent from a Highly Boosted Note 4!!!
05-27-2015, 09:11 AM | #25 | |
I haven't done the other test though Took a look at fuel pump strainer and it had a small forming at the bottom and a lot of dirt was in it, so i am replacing it tomorrow and maybe do a fuel pressure test whenever i find time. Last edited by zfortune; 05-27-2015 at 09:23 PM.. |
08-14-2015, 12:08 PM | #26 |
bring this back.... So I never fixed the code 34 and it's always coming back but I think it's actually reading correctly now and I'll explain why... So I followed fsm exactly to set timing. I am at 20 btdc with 750 idle. Then it says to do diagnostic mode II (oxygen sensor monitor) I put it in mode II ran for 2mins at 2k rpm but I am actually seeing the motor shake every 5-10 secs and hear a detonate noise coming from it. The check engine light did flash at least 5 times in 10 secs like the fsm states. Maybe I have to go back and check/adjust tps? Or what should I do. Currently have 91 octane for gas to.
New spark plugs/wires, rotor, and cap I did check all the wiring and everything for knock sensor and it's good. |
