01-23-2014, 01:57 PM | #1 |
Godspeed TD05 18G and TD06 20 Bottom Mount Turbo
Godspeed TD05 18G and TD06 20 Bottom Mount Turbo Both Driect Bolt on SR20 Redtop and Blacktop TD05 18G on the Left and TD06 20G on the Right TD05 18G TD05 18G Turbo Spec. Bearing system: Journal Bearing Compressor Wheel Diameter: 50.3 / 68mm TURBINE Wheel Diameter: 49.2 / 56mm Turbine TRIM: 57 Turbine flange type flange: T25 Downpipe flange type : 240sx 5 bolt type Nozzle Area: 8cm² Cooling type : oil and water cooled. Horsepower rating: 300-380 hp BOLT ON TURBO FOR S13 S14 S15 (SR20 MOTOR) Actuator set at : 14.5 PSI CFM: 600 Mod on our Time Attack 240SX, SR20 Redtop Stock with HKS CAM, Godspeed Intake Manifold , Turbo Manifold , Turbo Back Exhuast , Stock Piston and Rods YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 1st Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 2nd Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 3rd Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 4thd Pull more info. please check http://zilvia.net/f/tech-talk/323337...dyno-test.html TD06 20G This is on a Black top S14 with 650cc injector , stock internal and 14.5 psi. TD06 20G Turbo Spec. Bearing system: Journal Bearing Compressor Wheel Diameter: 58.8 / 68mm TURBINE Wheel Diameter: 58.8 / 67.14mm Turbine TRIM: 57 Turbine flange type flange: T25 Downpipe flange type : 240sx 5 bolt type Nozzle Area: 8cm² Cooling type : oil and water cooled. Horsepower rating: 400-450 hp BOLT ON TURBO FOR S13 S14 S15 (SR20 MOTOR) Actuator set at : 14.5 PSI CFM: 640 No Restrictor need for oil feed line TD05 18G $330 Shipped (Lower 48 State) $362.17 Shipped/Taxed (CA Customer) $310 Pick Up Preferred Cash TD05 20G (In Stock!!!! $450 Shipped (Lower 48 State) $493.87 Shipped/Taxed (CA Customer) $430 Pick Up Preferred Cash Please PM or email [email protected] for more info and payment method.
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject |
01-24-2014, 11:55 AM | #3 |
Til they are running out of stock. a week? a month? lol
