05-13-2017, 10:27 AM | #1 |
Hate to bring up electric fans but...
Ok so I've search here and Google and I might have missed something. From what I've read everyone runs relays of temp controllers. But just to try it out I hooked up my dual fans to the stock hi/lo wires that the old efan was hooked up to and bam hi fan kicks on with AC and high temp and when I was stopped the other fan kicked on to lower the temperature. Then as I was driving since I had air in my system (didn't want to add more coolant to leak out if it didn't work) it cause the car to overheat for Second and both fans kick on with the the ac off....so my question.... is this the wiring okay to do it? I have a temp control but why would I use it if the stock wiring is working???
I don't post on here much because I do my research... I've worked tons on my car but electrical just goes over my head sometimes.. thanks guys in advance. |
05-13-2017, 10:05 PM | #3 |
Stock ka24de The clutch fan went out last year but the electric fan was keeping it cool but I don't want to chance it this summer so I swapped the single electric fan for a dual fan with a shroud. Its the isr fans... And there is 4 wires that run to the stock e fan. One kicks on once the low temp is reach and the other when high temp is reached or ac is turn on.
05-14-2017, 05:55 AM | #5 | |
You definitely could if you simply used that circuit to trigger a relay and not for the actual power to the fan. Sent from my iPhone using Tapatalk |
05-14-2017, 01:41 PM | #6 | ||
GM2 (SW/AW)
Did the guy not use relays? I saw the word in there some where. If you're going to use electric fans run a relay. That's what they're made for. Obviously using your existing circuit isn't working properly so you should use the controller.
KA-T for life! Current for sale advertisement |
05-14-2017, 03:25 PM | #7 | |
So I personally would not rely on that circuit for Radiator Fan control. |
05-14-2017, 07:19 PM | #8 |
Get a DCC fan controller....little pricey but I haven't had any issues in 2 years...just wired it in was set to a good temp out the box and works perfectly with my Altima fans!
05-15-2017, 06:31 AM | #9 |
Well everything is working properly both fans work. My car doesn't over heat at all. I do have a temp control that I haven't hooked up yet only because the instructions are so blurry I can't read it lol. But if they work properly why add a temp control... Not trying to question people's knowledge but if it works properly why not trust the existing circuit?
05-15-2017, 09:35 AM | #10 | ||
GM2 (SW/AW)
Your original post says you did overheat. This one says you didn't. I no longer get what the point of you posting was? You either run a relay to power your fans with your existing +12v being the trigger to the relay. OR You run your fan controller.
05-15-2017, 11:15 AM | #11 | |
The ECU grounds the relays which trigger the fans so what you could do is add a thermoswitch to provide an additional ground for these relays at a lower temp. I was planning on getting a 185*F/85*C thermoswitch on the water neck and have the ECU as backup. Make sure you have good fans. I had the Mishimoto fans with the shroud and my engine overheated at speed. There simply wasn't enough airflow through the radiator and the fans didn't move all that much air to begin with. The altima fans kick ass and they fit on the 240sx radiators pretty nice with very little overlap. If you sealed this gap it would work more efficiently. |
05-18-2017, 03:05 PM | #12 |
It depends on what your definition of "working properly" is. If just having the fans turn on is good enough for you, then sure, maybe what you have now is good enough.
However, as I already explained, there's no documentation in the FSM on how that Condenser Fan circuit operates. Personally, I would want some kind of reassurance that my radiator fans will turn on, stay on and turn off as required by the vehicle's cooling system. That's what fan controllers are for. |
05-18-2017, 06:00 PM | #15 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
Keep in mind that your clutch fan will be the best option period as it spins with the speed of the motor and draws more air than any electric ever will, especially if you run a GK Tech fan (which draws 35% more air than the OE clutch fan does, plus it sounds fucking EVIL). Upgrading your cooling system also makes a HUGE difference. Pick up a 55mm Koyo Aluminum radiator, NISMO colder thermostat and GK Tech clutch fan replacement, you will have ZERO cooling issues... even if youre running A/C. I have all 3 in my S13 with an SR, I barely see temps over 175 in the middle of Summer when its like 120deg+ out in direct sunlight + asphalt! |
05-18-2017, 09:27 PM | #16 |
I stand corrected. I was looking in the HA section of the S13 FSM since OP didn't specify.
But I now see that there is similar information in the S13 FSM too: EC-26. So there you have it everyone: the information is in the FSM for you to decide if you would like to wire you aftermarket radiator fans this way. |
05-31-2017, 02:09 AM | #17 |
I have my electric fans wired through the factory condenser fan circuit. I have hi and lo grounded together so they both kick on at the lower temperature. My car typically stays around 70-80* C driving around, and in traffic with the A/C on. A/C seems to work better with two fans pulling through the entire condenser. On track days temperature will elevate to 90-100* C, but never really past that. Biggest thing is to use fans that actually pull decent cfms, the fans that come with the isr shroud are hot trash, I'm using 2 1300cfm 12" spals with a isr shroud.
@adamcs14 |
05-31-2017, 08:48 PM | #18 |
I run a Taurus oem relayed fan in both my rb and in my 1.5jz sc. they kick hot air's ass.
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
