Old 10-12-2018, 08:50 AM   #1
gary556
gary556 is an unknown quantity at this point
clutch pedal return spring install tips?
i'm trying to install the return spring in my clutch pedal and i'm just having a shitty time trying to compress the spring.
Anyone have any tips for installing it?
I got the whole pedal assembly out already
gary556 is offline   Reply With Quote
Old 10-12-2018, 09:42 AM   #2
slow2401989
slow2401989 will become famous soon enoughslow2401989 will become famous soon enoughslow2401989 will become famous soon enoughslow2401989 will become famous soon enough
Quick question where did you buy the spring?
slow2401989 is offline   Reply With Quote
Old 10-12-2018, 10:30 AM   #3
Agamemnon
Agamemnon's Avatar
My best advice is to take out the whole assembly. Its just easier that way and you can get better leverage to get the spring on. I couldn't figure out a real trick except using large pliers and patience. Also, make sure to wear work gloves. The spring can pinch your skin and leave some nasty blood blisters.
The dealership.
Old 10-12-2018, 10:55 AM   #4
gary556
bought a ton of parts including the spring at https://www.nissanpartsdeal.com/
im gonna have to take it to my friends house and use his bench vise to hold it in i guess. thanks for the tips
Old 10-12-2018, 11:46 AM   #5
slow2401989
perfect thank you
Old 10-13-2018, 07:30 PM   #6
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
I did this with my dash out and pedal still installed, so I had easier accessibility. Pretty much I slid one end into the hole and used needlenose pliers to try to force the other end into the other hole. I had to play around with it for a little bit but I eventually got it in, dont be afraid to use some force.
I would also recommend to get little bushings to prevent the pedal from squeaking; again this is from personal experience.
I got my spring from FRSport.
Skurr Skurr
DJTTon is offline   Reply With Quote
clutch pedal, help a kid out, install, spring
