10-01-2015, 02:47 PM | #12901 | |
10-01-2015, 03:06 PM | #12902 |
I remove the hardline completely and it's entirety, then I retro mount the charcoal canister in rear like tucked up and just have the vent from the tank going to it
10-02-2015, 04:11 PM | #12904 |
uploadfromtaptalk1443823869751.jpegwhat kinda front fenders r these
Sent from my SM-N915V using Tapatalk |
10-02-2015, 04:52 PM | #12905 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
10-05-2015, 10:16 PM | #12910 | |
10-06-2015, 02:57 PM | #12911 |
The Architect.
Need help identifying this Power FC.
Previous owner removed the sticker for whatever reason. Just need to confirm which model this is. Car was an S13 with a Redtop SR20 swap. Want to assume it's for a Redtop, but want to be sure. |
10-07-2015, 08:51 PM | #12913 |
Are these ZG flares? also aren't they different sizes front to rear?..
I got 18x9.5 -4 offset rims.. how would those fit with zg flares? i like the look of flares vs over fenders.. that's basically the look right their i'm going for.. thanks.
INITIAL D |
10-07-2015, 10:10 PM | #12914 | |
Trader Rating: (24)
Feedback Score: 24 reviews
IG: @Haley72692 |
10-08-2015, 02:07 PM | #12916 | ||
Think its explained here when he did the rest of the kit http://zilvia.net/f/showthread.php?t=433848 |
10-09-2015, 09:00 AM | #12917 | |
they are S30 ZG flares and yes they are different back to front, I would put some camber in the front and you can just roll the stock fronts flat and the rear you can run 30mm overs, I wouldn't run ZG flares with 18's, would definitely look goofy
10-12-2015, 09:14 PM | #12920 |
What is this plug for?
located in the p/s wheel well on an S14. It's coming from the same loom as the wiring for the water pump for the window washer reservoir. |
10-13-2015, 06:05 PM | #12921 |
if you have a kouki with no headlamp washers,could be for the missing washer pump
or you have a non rear wash/wiper model (only one pump in the washer bottle) |
10-14-2015, 09:26 AM | #12924 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
technically its a Vertex 180sx kit...
but yes, its also an extreme dimensions v-speed kit http://extremedimensions.com/89-94-2...speed-Kit.html |
10-14-2015, 07:42 PM | #12927 |
S13 Silvia Lip's f/s :www.codycasale.com
300zx, axles, body kit, bumper, die misinformation!, identify, j30, rare, search, what is this?, z32 |
