Old 11-02-2017, 10:16 PM   #1
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
Boost cut in 5th SR20
I'm having issues with the boost cutting in and out while in 5th gear mainly. While cruising in 5th and I floor it, I can hear the turbo spooling then pausing then spooling then pausing. Martin from R.S. Enthalpy says it is ignition related and it may be my P2M coil packs causing it.
Anyone ever have a similar issue?
I'll probably be warrantying out the coil packs since they are supposed to have lifetime warranty.
DennisC is offline   Reply With Quote
Old 11-02-2017, 11:53 PM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
YES!
I've had this issue more than once.
Coil & Injector.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 11-02-2017, 11:57 PM   #3
DennisC
DennisC's Avatar
Originally Posted by anti tyler View Post
YES!
Coil & Injector.
I have semi-new Deatschwerks injectors just installed and I had the same problem previously with the stock injectors. Most likely should be my coil packs then.
