Old 12-19-2018, 12:03 PM   #31
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
I completely understand the dynamics of ignition cut at high RPMs for SR’s, or any motor with rockers for that matter. My main concern was why that caused such low compression on other unaffected cylinders, because when I checked my mechanical timing the first time I was dead on. And I was even able to crank the motor until the marks on the chain and cams lined up again.
nisileighty is offline   Reply With Quote
Old 12-19-2018, 12:25 PM   #32
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
It doesn't take much for valves to not seal.........or be viewable by the naked eye
None of it matters anyways as your head is at the machine shop to yeah......
Old 12-27-2018, 06:40 PM   #33
pjurisprudencia
pjurisprudencia's Avatar
pjurisprudencia is an unknown quantity at this point
I had zero compression in my motor n cylinder 4, blew both Intake and exhaust. Put it all back together vacuum dropped due to me setting my timing wrong. Double check your timing
Don’t mind me, I’m just an irrelevant little shit.
pjurisprudencia is offline   Reply With Quote
