Old 08-17-2013, 01:03 AM   #1
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Gear Box Options for RB26 w/ 700hp
Background: I've searched for quite some time and haven't really been getting the answers I want. I plan to build up an RB26 single turbo setup capable of producing around 700hp. This setup will be placed in an S13 and be used strictly for drifting.
My Dilemma: I want to use something like a Jerico 4 speed or G-force transmission but finding someone who makes an adapter for them is close to impossible. I've researched transmissions that people do use currently and the hot seller seems to be an RB25 gear box outfitted with PPG dog cut gears. That's all well and dandy, but I have issues with that.
First off, PPG gear sets cost more than a Jerico transmission. Second, the RB25 transmission is huge. I know I'm going to be removing the transmission a lot and having a lighter more compact and easily rebuild-able transmission would be more of what I'm interested in.
My Question: Can anyone help me find or know of a local shop or a company that can make a gear box/gear box adapter for my application?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 08-17-2013, 01:32 AM   #2
genericforumname
Location: Florida, where we prove that shit does in fact run down hill
genericforumname is making a name for him/her selfgenericforumname is making a name for him/her self
should I even ask why you are concerned about the cost of a transmision when you are going to be building a 700 hp rb26? that makes no sense to me. coming from all the wrx guys PPG sets are one of the best single mods you can do, not only will they handle power but you get extra function out of being able to flat shift it also. if you really want to go with a 4 speed (really?) then any competent machine shop should be able to make something work if you get them the dimensions necessary for modding the bellhousing or an adapter to do the same. who knows, maybe MazWorx could make something, seeing as how they make conversion bellhousings for several other combinations.
genericforumname is offline   Reply With Quote
Old 08-17-2013, 01:43 AM   #3
ShadowDrifter
Trader Rating: (55)
ShadowDrifter is an unknown quantity at this point
Feedback Score: 55 reviews
You DICK LOL JK im doing the same build only im going for around 600 good luck becasue im looking for the same options
Drifters Do It Sideways
ShadowDrifter is offline   Reply With Quote
Old 08-17-2013, 01:46 AM   #4
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Look into PAR gears. They are a bit more affordable than PPG.
PAR Catalog
Quaife also makes gear sets.
Anything else will need to be custom.
Apparently Hollinger is 'the best.' Also the costliest.
http://www.holinger.com.au
Old 08-17-2013, 02:10 AM   #5
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
why not use a z33 trans or z32 trans and adapter?
SW Fab
shiftdrift is offline   Reply With Quote
Old 08-17-2013, 04:54 AM   #6
soundboy
soundboy is an unknown quantity at this point
Rb25 gearbox will work. Get some gear sets and a good clutch
Sent from my GT-P3110 using Tapatalk 4
soundboy is offline   Reply With Quote
Old 08-17-2013, 06:28 AM   #7
R33E8
R33E8 is an unknown quantity at this point
It's not terribly expensive to make that much power... All you need is a larger turbo and more fuel.. I wouldn't be surprised if the cost of the transmission is equal or greater than what was spent on the engine.. I have a fully built KA setup to make around 7-800whp.. The gearset alone from PPG cost more than what I put into my entire setup...
The z32 trans uses the same internals as the RB25 trans. I've heard that that rb25 trans actually comes with better syncros..
R33E8 is offline   Reply With Quote
Old 08-17-2013, 09:43 AM   #8
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
Depending on the exact setup, making an RB to (whatever) adapter plate shouldn't be too hard for a competent machine shop. You should be able to take both bell housings to a shop, have them plot the critical geometry (ie bolt/pin holes) and then have them knock out an adapter plate.
Or the alternative is that they cut two bell housings and weld them into one. Either way contact some local machine shops and see if they're willing to give it a shot.
thefro526 is offline   Reply With Quote
Old 08-17-2013, 06:53 PM   #9
soundboy
Flex plate and clutch would be the hardest part. The bell housing is the easiest part
Old 08-17-2013, 07:08 PM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
OS Giken gear sets into the RB26 transmission, modded to RWD configuration by cutting out the transfer case and welding a plate on the housing. Be the last transmission you'd need considering guys are pushing over 1K hp on that with no issue.
CLICK HERE!!!
Old 08-17-2013, 07:31 PM   #11
OutToWinPAHC
OutToWinPAHC's Avatar
OutToWinPAHC is an unknown quantity at this point
Send a message via AIM to OutToWinPAHC
Someone had used a tremec TKO unit on a RB recently, I believe it was a 5 speed model. From what I remember spec made him a custom flywheel, and the crank was machined to fit the roller bearing to match the trans shaft as well as a custom bell.
OutToWinPAHC is offline   Reply With Quote
Old 08-18-2013, 09:28 AM   #12
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
Try to talk to (driftsquid) Jake Jones ! He's running a g-force gsr on is rb25 !
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 08-18-2013, 10:35 AM   #13
BossHogg
BossHogg's Avatar
BossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really nice
Heh if he crying about ppg he need look at os giken stuff. Although that would be badass.
BossHogg is offline   Reply With Quote
box, dog, drift, gear, rb26
