Old 03-17-2018, 07:02 PM   #1
RickyBobbyS13
RickyBobbyS13 is an unknown quantity at this point
S13 blacktop sputtering hard under WOT
So I’ve got an S13 blacktop in my car and under full throttle it’s running like it has a boost leak. Sputtering and stops building boost. I’ve leak checked the whole car for any possible boost leaks and fixed any I found. Car starts, idles drives down the road fine just cruising but once I try to get into it it builds a little of boost and the sputters and stumbles all over the place. I’ve done plugs and coil packs as well as 255 fuel pump and new filter. Car runs a solid 10.0 on the wideband so it doesn’t seem to be any fuel issues.
Any insight is appreciated. Thanks.
RickyBobbyS13 is offline   Reply With Quote
Old 03-18-2018, 08:33 AM   #2
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
You have way too much fuel. idk about your wideband but mine actually bottoms out at 10 and wont read any lower
is this a name brand 255?
how long does it take to recover?
does it instantly sputter and stumble when you get on it everytime?
and why are you running so damn rich
The Game
you lose haha
kyral is offline   Reply With Quote
Old 03-18-2018, 08:40 AM   #3
RickyBobbyS13
Its an ISR 255LPH fuel pump and yes my AEM wideband doesnt read anything less then a 10.0 on the gauge. It will run fine and drive fine under normal conditions(14.7 while cruising) and it only happens when really trying to get on it. Boost gauge spikes all over the place around 5lbs and runs like trash, as soon as i let off itll drop off and go back to running fine. I will be checking my injectors today to see if i have a possible stuck one at WOT?
Old 03-19-2018, 05:02 AM   #4
RickyBobbyS13
Bump. Any ideas?
Old 03-19-2018, 08:30 AM   #5
jedi03
tune, flooding, coil pack...could be a lot there...
Old 03-19-2018, 08:35 AM   #6
RickyBobbyS13
Brand new coil packs, spark plugs. Car is stock aside from intake/exhaust. Shouldn’t need a tune
Old 03-19-2018, 09:34 AM   #7
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
Describe how you checked for boost leaks.
blkvrtswp is offline   Reply With Quote
Old 03-19-2018, 09:36 AM   #8
RickyBobbyS13
Used a boost leak tester off the turbo and pressurized the system listening for leaks and using soapy water on everything
Old 03-19-2018, 11:33 AM   #9
heywier427
heywier427 is an unknown quantity at this point
Why/when did this start occurring?
Plugs gapped to 28-32?
heywier427 is offline   Reply With Quote
Old 03-19-2018, 11:40 AM   #10
RickyBobbyS13
Been happening since I got the car; was told it never had any issues prior to me owning it but we all know how that goes.
Plugs are gapped to a .28 and am getting a “55” from the ECU.
Old 03-19-2018, 12:09 PM   #11
heywier427
Try unplugging the maf and see what you get.
I believe code 55 means there is no codes.
How the pcv valve?
Old 03-19-2018, 12:13 PM   #12
RickyBobbyS13
Unplugging the maf makes it almost die out and run rough so I figure the maf is working correctly; haven’t checked the PCV or iacv. Also wondering if it’s something dumb like the o2 being bad or something.
Old 03-19-2018, 10:10 PM   #13
nissansrdub
nissansrdub's Avatar
nissansrdub is an unknown quantity at this point
Injector o-rings. One is probably torn or pinched.
nissansrdub is offline   Reply With Quote
Old 03-20-2018, 09:03 AM   #14
blkvrtswp
blkvrtswp's Avatar
Hmm, boost leak test procedure sounds ok. How high did you see the pressure get to on your boost gauge during testing?
Old 03-20-2018, 09:16 AM   #15
RickyBobbyS13
Maxed out 5lbs on my gauge which makes me think I have a faulty gauge as well. I will take a look at the injector o-rings when I get home as well. I ordered a pro sport electronic setup to see if I can’t get a true reading.
I am truly stumped on this as the car runs phenomenal aside from WOT or 0-full acceleration.
Old 03-20-2018, 12:15 PM   #16
heywier427
Or you have a ginormous leak somewhere!
Just unhook the boost gauge signal hose and run air pressure to it. Should easily go to 20-30 psi with an air hose. Maybe the hose to the gauge is split somewhere?
Old 03-20-2018, 12:27 PM   #17
RickyBobbyS13
Very possible as well. Once I get this new gauge setup it should have much better material for the boost line itself.
This leak must be somewhere crazy because I have tested it and can’t find it anywhere.
Old 03-20-2018, 06:26 PM   #18
blkvrtswp
blkvrtswp's Avatar
I would want to see 15+ lbs on the gauge to rule out boost leaks.
Old 03-20-2018, 08:45 PM   #19
nissansrdub
Don’t forget to lube up the injector o-rings before popping the injectors back in
Old 03-21-2018, 08:44 PM   #20
RickyBobbyS13
So I’ve done it all. Still no change. Makes zero sense.
Old 03-22-2018, 09:13 AM   #21
heywier427
pinch off hose going to pvc valve?
How are your brakes? If you live in a not to congested area, or if you can drive to one, pinch off your brake booster line.
Are you able to do a pull, get it to mis, turn off the engine while missing, and then pull the plugs to check the color? Try not to get the turbo super hot while doing this.
Ripped diaphragm on bov?
Old 03-22-2018, 09:17 AM   #22
RickyBobbyS13
Hoses seem to be clean to PCV valve, brakes are good. But I’ll try to pinch off the vac line to the booster. I’ll also do a pull to check the plugs and see how wet they are. I removed all the IC piping and re installed checking for cracks and holes and didn’t find anything.. bov has a good deal as well
Old 03-22-2018, 10:26 AM   #23
heywier427
Not so much to see if theyre wet, but the color. Which ever cylinder is missing, the color at the tip of the plug is going to be white/light tan, compared to the others which will be black if running in the 10's.
Could be worse. You could be working on a volkswagen
Old 03-22-2018, 04:38 PM   #24
RickyBobbyS13
So after looking at it today; I turned it to key on power and heard what sounded like air coming from around the FPR, is that my mysterious leak or is that normal?
