Old 12-06-2017, 05:50 PM   #1
outfronts13
outfronts13 is an unknown quantity at this point
Mishimoto Radiator
So i purchased a fairly new Mishimoto Radiator for my 1990 240sx and I am having trouble mounting it to the stock oem mounts. The radiator itself sits fine and will mount to the top oem mounts yet is around 1in off the stock lower mounts do to the thickness of rad. Mishimoto only makes one radiator for all 240sx from 89-98 and they state it fits my car. Do i have to fab some mounts or im i doing something wrong? Im new to cars in general.
outfronts13 is offline   Reply With Quote
Old 12-06-2017, 05:51 PM   #2
nisileighty
nisileighty's Avatar
nisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nice
Pretty sure s14 and s13 doesn’t have the same radiator, so that may be for an s13
nisileighty is offline   Reply With Quote
Old 12-06-2017, 05:53 PM   #3
outfronts13
You mean an S14? on mishimoto website the part number is the same for a s13 rad an s14
Old 12-06-2017, 05:54 PM   #4
nisileighty
Yeah, my bad. Mishimoto may be incorrect.
Old 12-06-2017, 05:56 PM   #5
outfronts13
The guy i got it from said he had it in his vert so it weird i might fab something up for the meantime i tiewrap hell out of it
Old 12-06-2017, 06:07 PM   #6
outfronts13
I thought the upper mounts are only thing different from s14 and s13 rad.
Old 12-06-2017, 06:11 PM   #7
TheRealSy90
Four Lug Swap
TheRealSy90's Avatar
TheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud of
Something sounds off. Do you have the rubber feets on the two bottom mount posts? Try posting some pics with the rad mocked up. I don't think there's even enough room in that area for the mounts to be an inch off lol.
Such a good signature.
Old 12-06-2017, 06:12 PM   #8
outfronts13
I will take pics tomorrow once i get off work. No i dont have rubber feets is that a good or a bad thing
Old 12-06-2017, 06:13 PM   #9
nisileighty
That’s your problem. They’re little grommets that go in the bottom hole to hold it in place.
Old 12-06-2017, 06:16 PM   #10
outfronts13
So i need to get those what about were the radiator actually bolts on that is that is off
Old 12-06-2017, 06:18 PM   #11
outfronts13
my stock Rad was on with two 10mm bolts and top mounts
Old 12-06-2017, 07:30 PM   #12
DRIFTING_SIL_EIGHTY
DRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to behold
Whats the part number of your radiator? Mishimoto makes the radiator specific to the chassis.
S13 - https://www.mishimoto.com/nissan-240...-89-94-ka.html
S14 - https://www.mishimoto.com/nissan-240...-95-98-ka.html
DRIFTING_SIL_EIGHTY is online now   Reply With Quote
Old 12-06-2017, 08:12 PM   #13
outfronts13
Mmrad-240-89ka,which means it should fit fine so i guess i need to get those rubber installation pieces
Old 12-06-2017, 09:15 PM   #14
DRIFTING_SIL_EIGHTY
Double check your old radiator to see if the rubber grommets are still there. If they are just slip them on the new one. If they're not, junkyard or just buy new.
Old 12-08-2017, 04:15 AM   #15
carlos.leandry12
carlos.leandry12 is an unknown quantity at this point
Mishimoto Radiator
Yeah they’re different, the bottom mounts in the core support line up but no the top ones and the location of the coolant overflow is opposite
carlos.leandry12 is offline   Reply With Quote
Old 12-08-2017, 08:22 AM   #16
mechanicalmoron
mechanicalmoron is making a name for him/her selfmechanicalmoron is making a name for him/her selfmechanicalmoron is making a name for him/her self
Those rubber mounts often stick to the old radiator, and it's often just long enough to drop somewhere down the car. You had them, Go find them.
mechanicalmoron is offline   Reply With Quote
