Old 12-30-2016, 09:20 PM   #1
clydesfstbk
clydesfstbk is an unknown quantity at this point
Manual transmission question
Anybody ever pull a stock shifter out of the trans ? Having trouble getting it back in
:2f2f
clydesfstbk is offline   Reply With Quote
Old 12-30-2016, 09:46 PM   #2
hollerjeet
hollerjeet's Avatar
Trader Rating: (18)
hollerjeet is an unknown quantity at this point
Feedback Score: 18 reviews
it should just slide back in with some wiggling. If i remember correctly, you should have the plastic bushing at the end of the shifter, then the plastic cap that sits on the top of the round ball of the shifter ( if that makes sense) and lastly you have the snap ring.
just insert the shifter back into the trans, till the plastic cap seats, then with some snap ring pliers ( or needle nose and flat head screw drivers) insert the snap ring in and it'll be good to go homie!
hollerjeet is offline   Reply With Quote
Old 12-30-2016, 10:57 PM   #3
jedi03
Sometimes the plastic bushing gets cocked a little off...that could be causing issues...
Old 12-31-2016, 06:54 AM   #4
snags
snags's Avatar
snags is an unknown quantity at this point
you have to spit on it... should squeeze in
snags is offline   Reply With Quote
Old 12-31-2016, 08:42 AM   #5
clydesfstbk
Got the shifter back in properly now just have to get both snap rings in, looks like the larger one of the two fits in the groove only and the smaller snap ring is kinda a shim
:2f2f
