Old 04-19-2002, 07:54 AM   #1
mrdirty
mrdirty is an unknown quantity at this point
Does anyone have any advice for changing the t/c rod bushings? What should I do, torch the old silicone out then press in the new one?
C'mon that whole new unit is like another $100...
Help
mrdirty is offline   Reply With Quote
Old 04-19-2002, 08:25 AM   #2
bbp
bbp's Avatar
bbp is an unknown quantity at this point
Use a press to press the old bushing out.  You can torch it if you want, or use the press to tear it out.  Once you have it torn up a bit, you can use a hacksaw to GENTLY WITHOUT CUTTING THE ARM, cut a slot int he outer sleeve of the old bushing.  This will relieve the pressure and allow it to come out easier.
bbp is offline   Reply With Quote
Old 04-19-2002, 09:42 AM   #3
mrdirty
Great thanks, any advice on getting the new one in?
I'm going with the whiteline poyurethane ones
Should i stick it in the freezer?
Old 04-19-2002, 09:52 AM   #4
bbp
bbp's Avatar
no the press in really easy, just lube em up!!
Old 04-19-2002, 10:06 AM   #5
mrdirty
Ok, so it seems that getting the old ones out is the biggest pain, why does PDM make such a stink about finding a shop who will press them in? Like it's so difficult that no-one will take it on?
The old one can't just be cut out huh? I guess it's not all just rubber and silly-cone.
Old 04-19-2002, 10:18 AM   #6
mrdirty
Can I just use a bench vise in some creative way instead of a press? I don't have access to a press.
Old 04-19-2002, 11:17 AM   #7
bbp
bbp's Avatar
You will def. need a press to get them out, may be able to get them in with a big vise.
Old 04-19-2002, 11:56 AM   #8
mrdirty
Since i don't have a press, will torching be my only option?
Can't cut 'em huh?
Thanks again, for all the help...
Old 04-19-2002, 12:04 PM   #9
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
It can be hard to get them aligned right when you press them.  It kept wanting to pop out to the side right before it was about to go in.  It finally went in with a lot of lubrication and persistence.
LanceS13 is offline   Reply With Quote
Old 04-19-2002, 12:09 PM   #10
mrdirty
do i need to protect them at all? will the vise damage them? How'bout cooling them down to make 'em smaller?
