07-27-2012, 05:38 PM | #1 |
Trader Rating: (26)
Feedback Score: 26 reviews
F/S/T!xHKSxGREDDYxENERGYxSR20x5LUGxPERSONALxOEMxMEGANx N62xSILVIA PROJECTORSxDMAX
If you view this, please give a courtesy bump for a wounded soldier. I appreciate it! *I WILL SHIP ANYTHING LISTED BELOW* Alright folks. I'm trying to make some room in my garage, finish my project, and trade away some parts. Below are the items with descriptions as well as condition if applicable. I am taking trades and that list will be below what I have to offer. Also, my contact information is below that. I just returned from deployment via MED-EVAC so I have some more free time to wrench on the car and hopefully once and for all finish her... for now. I do NOT have set pricing on these items. Please make an offer either here for via PM but please bump this if you read/view this thread. On for the items! ITEMS: 1. BRAND NEW Energy Suspension subframe inserts, S13. Bag is opened so I can pull out the sheet to confirm it's confines. 2. BRAND NEW Energy Suspension tension rod bushings Bag is opened so I can pull out the sheet to confirm it's confines. 3. Megan rear sway bar end link bushings. Very lightly used. Got them with the Tanabe SUSTEC and since I bought the master kit from Energy Suspension, I threw those on instead. 4. BRAND NEW Energy Suspension rear sway bar bushings Bag is opened so I can pull out the sheet to confirm it's confines. 5. BRAND NEW Energy Suspension rear control arm/spindle bushings 6 of them are used. I replaced my spindle bushings with these. 6. Front 4-lug setup with rotors and brakes, will seperate Can include brakes, the are S14 SE brakes, same goes with the rotors. Bearings in the hubs are mint. 7. S14 front brakes with lines and rotors, will seperate Pulled them off my car before I went full Z-brake setup. 8. J30 front 5-lug setup SOLD SOLD SOLD Axel nuts and dust cups are included. All you need for the swap are to press in the S13 bearings after removing the J30 bearings. Brakes pictured above are the J30 brakes. 9. J30 front brake setup Pictured above. Come with no lines. 2 of the slider bolts are missing but can be replaced with other brake bolts or at Home Depot/Lowe's. Probably cost 2-3$. 10. Aftermarket manual boost controller Don't know much about it. I know it works, though. Came off a Civic. 11. S13 manual transmission crossmember with Megan transmission mount Crossmember just needs a good cleaning and the mount is practically brand new. No signs of wear or tear on either. 12. Yakima lock and key set Not sure what is missing. Found this in my car after selling off the rack. Comes with 2 different keys, a lock cylinder, and some dummy cylinders. 13. S13 SR20DET OEM cams and cam gears Came out of a running car, just decided to upgrade my spare head. 14. BRAND NEWS13 hatch rear dampers Came off a parts car that had these in the box in the rear trunk. They were mounted but never used as weird as it is to say. 15. DMAX clear S13 front bumper lights Need a little cleaning but no cracks. Bulbs and harness included. 16. BRAND NEW Sylvania glass S13 headlights Have a little overspray on one but nothing a good washing wont fix. Other one is mint. Both have only been mounted, never used. 17. 340mm PERSONAL classic deep dish steering wheel Black stitching, NO damage that I can tell. Does not have a horn button. The one I got with it didn't fit. NRG release and mount are NOT included. Please do not ask. Apparently, this is a 1979 model in absolutely MINT condition. Own some history. Compare here. 18. Key lock cylinder, S13 Key is not included because I misplaced it. Had to replace this one with the lock cylinder that came with my kouki 180SX tails. Worked perfect when I had the key. 19. HKS suction air filter It has seen better days. Was on my car and scraped against the ground when the mount cracked and broke off. If it doesn't sell cheap, it'll go in the garbage. 20. N62 MAF's. I have three of these all with decent sized pigtails. They all were tested and work. 1 IS SOLD, 2 LEFT! 21. Silvia triple projectors Have been professionally modified to accept H4 in the low beams, will combine with the grille. No cracks or missing tabs of any kind. 22. Silvia center grille No cracks or missing tabs of any kind. Will combine with the triple projectors. 23. GReddy PROFEC II electronic boost controller Comes with control box and solenoid. The harnesses were both damaged when I got them but new ones can be purchased for car-specific applications for under 35$. TRADES: EVERYTHING must be for a S13 hatch, SR, or be authentic [for the most part] I can add if needed depending. 326 trunk wing Roof wing SR upgrade parts [cams, valves, retainers, rods, etc.] Rear overfenders Kit [pop-up front] Z32 e-brake setup [complete with 2+2 lines and brackets] OBTAINED. Other dopeness CONTACT: AIM - JAYJAYBREAKSJAWS Text/call - 401 533 4834, name is Jay. PAYMENT: I'm a verified PayPal user. Be prepared to add for fees and shipping unless we work a deal. I use flat rate boxes and try to ship cheapest route possible to save buyers some cash. Last edited by SupaDoopa; 08-04-2012 at 03:41 AM.. |
07-28-2012, 12:44 PM | #7 |
Free bump for the greatest country in the world and the people who defend it! Also hit me up with a price on the triple projectors.
Parts i need:*Jdm hatch headliner (gray no sunroof)*Silvia horn button |
08-03-2012, 07:26 PM | #18 |
i want some of this stuff but where are your prices
hardpark.net |
08-06-2012, 02:53 AM | #22 |
Location: Hometown: Waukesha WI, Current resident of: Forest City NC, Moving to: Arizona PHX area
how much for triple projectors and grille shipped to 28043. or just grille. into any trades? I have a FS thread on Zilvia, take a look
1/89 s13 XE. Tilton pedal box 5lug VLSD Sil front z32 brakes Volvo 5cyl w58 |
08-06-2012, 06:51 PM | #25 |
That steering wheel is hella tempting, pm me best price shipped please. Bump for you.
dmax, greddy, hks, personal, sr20 |
