05-13-2011, 05:29 PM | #1 |
90' - 2JZGTE T61 Single - MKIII Supra - 5SPD- CLEAN!
PHONE NUMBER: 847.371.1475 EMAIL: [email protected] LOCATION: Chicago, IL PAYMENT PREFERENCE: Check, Cash, Money Order, Paypal (Transaction Fee), bank certified check or Credit Card (Transaction Fee) Background: Car was originally a Texas car brought up here to IL. Went through one winter at the dealership, but every since then it has always been garage kept and spent most of the 4 years I have owned it under Florida weather. Chassis has 165k on it and does not look the part at all. Pictures speak for themselves, the car is very clean for its age! Motor has a little under 10k miles on it. It's NEW! :-) Car has not had any accidents, all VIN stickers in place and has a clean car fax report, you more than welcome to run one on the car. I have done all the work myself, some of you here on the forums know are familiar with my work. I do my own work and that I do it right the first time. Current Status: Car pulls hard. 10psi running off the wastegate. Everything works! Heater, power steering, A/C, all electronics, e-brake, everything! Like it should, from factory. Specifications: - Motor - 2JZ-GTE (Aristo) Motor - Rebuilt and has 10k miles since the rebuild (and some cause I drive it from time to time) T61 Turbo TreadStone Cast Manifold (Port Matched) 38mm Wastegate (8psi Spring) 3" V-band Downpipe 1JZ FMIC Piping Stainless Oil Feed Line Custom Earl Fittings and Stainless Oil Drain Oil Pressure Gauge at feed line 2.5" Intercooler Piping with Bead Roll (Wont pop an intercooler hose, no way) Bosch Blow-off Valve Doctor Tweak Plug n'Play Wiring Harness NEW OEM Toyota Piston Rings NEW OEM Toyota Engine Bearings Block Re-Honed NEW OEM Toyota Oil Pump (Modified for extra pressure and flow) NEW OEM Toyota VSV's NEW OEM Toyota Gasket Set (Top to Bottom) NEW OEM Toyota Valve Stem Seals Rebuild Head (Acid Dipped and Freshen'd up) NEW OEM Toyota TPS Sensor New Timing Belt New Serpentine belt NEW OEM Toyota Serpentine Tensioner NEW Upgraded Radiator NEW OEM Toyota Condenser NEW OEM Toyota Air Conditioning Pump NEW OEM Toyota Vacuum Lines to all VSV's New Thermostat NEW OEM TOYOTA Front and Rear Main Seal Transmission: R154 Transmission (50,000 miles) ACT STAGE III 6-Puck Clutch 1JZ Flywheel (OEM Lightened) Factory 5-Speed Pedals Installed Brand New Rear Transmission Mount Brand New TOYOTA Shifter Bushings Redline MT-90 Oil Suspension: Eibach Pro Springs KYB Struts Rebuilt 3.73:1 Clutch-Type LSD Brand New Rebuilt Power Steering Rack Energy Suspension Polyurethane Steering Rack Mounts Custom Alignment Braking: Authentic Brembo Cross-Drilled Rotors Hawk Street/Race Pads GoodRich Stainless Brake Lines Electrical: Apline CD Player RockFord Fosgate Speakers Front to Back New Odyssey Lightweight Battery Relocated to the Trunk Main Battery Cut-off Switch Built-in Gauge 1 Wire for all connections Factory Antennae Works Flawlessly Cooling: OEM Toyota Radiator Upgraded Power Steering Pump Cooler Radiator Coolant Over-Flo Relocated NEW SAMCO Lower Radiator Hose Hi-FLO Condenser Fan NEW TOYOTA 2JZ Clutch Fan Misc Modifications: T61 Turbo K&N Air Intake Custom Full Exhaust from Turbo all the way back (All Mild-steel, has stainless flex pipe and v-band stainless clamps the whole way) Walbro 255 Fuel Pump Power Steering Reservoir Relocated with Stainless Lines and AN Fittings R134 A/C Conversion 2JZ-GTE ECU Fits in the Factory MKIII ECU location. Usually people lose a glove box, I made the factory 2JZ ECU fit snug in the factory location. Price: Price Update: $9,600 OBO Notes: People are more than welcome to contact me for any questions over the car. I have done all the work to the car and I am very well versed in all aspects of the vehicle. Pictures: UPDATE: Pictures are current of the car even though the pictures were taken a month earlier. Only thing is, these dont have a shifter boot like above. Only difference. Let me know if you have questions. AUTOCHECK ON THE CAR!!!!!!!!!! CAR IS CLEAN AND FREE OF ALL ACCIDENTS! UPDATE: Took the car to the Sound Performance OPEN-HOUSE and put the car on the dyno. Car put down 304whp just running 10psi. No tune. Running rich. Just stock computer, intake, exhaust and single T61. All on a JDM 2JZGTE that running a stock computer with conservative timing values and the JDM cams which are less aggressive than the USDM ones. Power is spot on for where the motor is at mod wise. Photo: Video: Dyno 1 - ‪2JZ-GTE MKIII Dyno - 1‬‏ - YouTube Dyno 2 - ‪2JZ-GTE MKIII Dyno - 2‬‏ - YouTube Videos: YouTube - Supra MKIII 2JZ - Walk around YouTube - MKIII 2JZGTE Under the Hood YouTube - Supra MKIII 2JZ - Rolling 2nd Gear Pull - I YouTube - Supra MKIII 2JZ - Rolling 2nd Gear Pull - II YouTube - Supra MKIII 2JZ - 1st gear through 3rd YouTube - Supra MKIII 2JZ - Rolling 2nd Gear Pull from outside YouTube - Supra MKIII 2JZ - 1st gear through 3rd - From outside YouTube - The Fonz Drives the 2JZGTE T61 MKIII Supra Last edited by oem_turbo; 07-21-2011 at 11:14 AM.. Reason: PRICE Update |
06-08-2011, 07:04 PM | #3 |
06-14-2011, 06:15 PM | #10 |
trade for a 1997 sc400 with megan coils, 97 supra seats, jdm turn signal, 02 gator shifter and a carbon hood.
lmk man.
1994 240sx SE- SOLD 1983 Cressida - Factory 5spd. |
06-15-2011, 07:46 PM | #13 |
i have a 09 gti on fk coils im willing to trade you, i owe 10k on the car so my gti+you take over payments for yours.
VWVortex.com - 09 gti on coils 44k f/s/t orlando looking for mk2-mk4 if not glws |
2jz, supra, t61, turbo |
