01-30-2017, 12:32 PM | #3811 |
Can a 265 tire fit under an s13 without fender mods? Racing rules (scca stx) dont allow me to change the body but im allowed up to a 265 on a 9 inch wide wheel. (Wheel diameter has no restrictions) my current thoughts are to run a 17x8+25 with 255/40r17 re71r. Anybody know if that would fit?
01-31-2017, 10:07 AM | #3812 | |
Instagram:https://instagram.com/jpacione/ |
01-31-2017, 10:43 AM | #3813 | |
01-31-2017, 11:46 AM | #3814 | |
02-11-2017, 04:16 PM | #3815 |
Trader Rating: (68)
Feedback Score: 68 reviews
Ok guys let me try this again since I got no responses regarding my questions last time. Will include COMPLETE details for consideration on wheel size.
Im looking to upgrade the wheels on my '97 kouki. The car currently has 40mm D-max front fenders and 50mm Origin V.1 rear overfenders. I have kei-office type XR coilovers and all suspension arms are adjustable including lower control arms. I am running Z32 f/r brakes with e-brake. Car sits very low and don't want to raise it up much high then it is now. What Im looking into for is a wheel/tire combo that sits flush with the fenders but is NOT super stretched. I understand some stretch will be required to maintain the low height of the car. I also am completely against running spacers. What to run in the range of -3.5 degrees camber in the front and -1.5 degrees in the rear. Willing to adjust minimally from there but dont want a bunch of camber eating the tires since this will be predominantly a street car. What I am considering is an 18X10 +13 F and 18X11 +0 R with 255/35 F tire and 295/35 R tire. Tire sizes are not set in stone but I want to keep the width in that general area since I believe it will offer the stretch needed to fit but wont be super stretched. With these wheel and tire sizes and all details listed above taken into consideration, will I have issues with the wheels hitting the coilovers? I plan to tub the front fenders in the near future so tire rub shouldn't be an issue on the front. Do you guys think the rear will have substantial rub? I will be smoothing the inner lip of the overs as well as slightly bowing them if needed. Please any suggestions or pointers in the right direction would be MUCH appreciated. Thanx, Cameron |
02-28-2017, 08:19 PM | #3817 |
About to rebuild my blitz 03s for my s13 Silvia... trying to figure sizing for stock body with rolled fenders. Max lip? Any help is appreciated.
IG @hardparkedsilvia |
02-28-2017, 09:55 PM | #3818 |
225/40/18 front
245/40/18 rear |
03-06-2017, 07:10 AM | #3819 |
Trader Rating: (26)
Feedback Score: 26 reviews
Running 19x12 on my SC and looking for mild stretch for better fitment but also safe enough for decent speed sliding. It looks like the tire brands are slim picking in a 19 but these aren't going to be slid on very often. What tire size do you intelligent folks recommend? Probably going double stagger, too.
03-11-2017, 03:44 PM | #3820 |
Trader Rating: (24)
Feedback Score: 24 reviews
ive done 17x9 et0 fronts and 17x10 et10 rears on mine and thats the most aggressive id go on stock body with minimal camber, lip size will depend on what disk-type the faces are so i cant be of any help there
IG: @Haley72692 |
03-15-2017, 07:06 PM | #3822 |
Have MB battles 18x9 +15 square
245/40r18 Have a chance to buy Vs Kf 18x8 +9 (might be 8.5)r disk 18x9 +20 ( might be 9.5)o disk Double checking the might be Like my current set up Would that be possible with these? If I build them out |
03-15-2017, 07:07 PM | #3823 |
245/40r18 Have a chance to buy Vs Kf 18x8 +9 (might be 8.5)r disk 18x9 +20 ( might be 9.5)o disk Double checking the might be Like my current set up Would that be possible with these? If I build them out Forgot to add the car is a 98 kouki with the Evo 8/9 front brakes Last edited by billyblaze; 03-15-2017 at 07:12 PM.. Reason: For got for what vehicle |
03-15-2017, 09:11 PM | #3824 | |
03-16-2017, 08:09 AM | #3827 |
Car has been sitting since I've thrown on a set sqaure g8s 18x9.5 +12 and havent driven the car yet due to motor issues but noticed on that I rub so much. Nothing on the fender but basically the fender well/firewall area. Way in the back side of wheel well. Havent looked too much into it besides locking the steering and feeling it rub and seeing it when I set outside of the car. My uncle sells lazer alighment machines so I did one the one day to dial best I can to clear my front/rears with like roll/pull. Cam out perfect but my camber is maxed out at -2ish all around. My caster rods up front have been maxed out since I got the car. Theyre the normal bright yellow v1 isr arms.
What are my options besides getting a hammer and bashing it? Should I get new arms that can give more adjustability and is there something else im missing that can nudge the wheel slightly more forward besides caster? Toe is good and camber is about 2ish degrees. Will take pictures later but fitment is perfect up front and I'd hate to raise it. I can see by maybe going up two inches will clear it but will probably rub when turning full lock and going over a bump. I know loads of guys run more aggressive fronts and even similar specs and never herd much about rubbing on the body side? |
03-16-2017, 04:20 PM | #3828 |
Okay so I may need the information by tomorrow before I order the wheels. I believe they should fit, but I want to be fact checked.
Will Medium disc VSKF wheels fit my car with these size lips? Fronts: 5" Lip Rears: 5.5" Lip Car: Nissan 180sx 40MM Front Fender 50MM Rear Fender
03-19-2017, 09:11 PM | #3829 |
I got set of 17x9 +35 for my s13 coupe after reading through this thread should i just get 15mm spacers for the front & rear (or just the front) and go with Federal SS595 215/45/17 all around?
03-19-2017, 11:08 PM | #3830 |
Thinking about going with 18X9.5 +15 for 2001 GS300, how would they fitment run?
Thanks! Last edited by DaiGurren; 03-19-2017 at 11:08 PM.. Reason: spelling |
03-20-2017, 03:32 AM | #3831 | |
Trader Rating: (77)
Feedback Score: 77 reviews
Sounds like a good setup. Post some pics when it's all said and done.
03-20-2017, 03:39 AM | #3832 | |
Trader Rating: (77)
That would be the max wheel size I'd run on OEM body though. Ideally, I'd run 9.5" with around 10-15mm offset in the front and 10.5-11" and 12-18mm outback for a stock body S13. But that's just me.
03-20-2017, 03:48 AM | #3833 | |
Trader Rating: (77)
03-20-2017, 03:49 AM | #3834 | |
Trader Rating: (77)
03-20-2017, 12:01 PM | #3837 | |
Trader Rating: (77)
I'd install everything then test fit the wheels and your desired tire size first before ordering spacers. 215 and 9" wide wheels should look and drive just fine. I run 225 on my 9.5" front. Sent from my iPhone using Tapatalk
03-20-2017, 01:54 PM | #3838 | |
I think Im going to go order some spacers. Im really picky with parts so I might just spend the bread and go with PBMs. |
03-20-2017, 09:39 PM | #3839 |
I used to have 17x9 +25 with 215/45-17 in the front on my s13. It was damn close to the coilover, +35 will most likely need spacers. And I would recommend a 40 series tire over the 45, the 45's were too big for my liking. Good luck!
03-23-2017, 12:05 AM | #3840 |
Just got knoops old s14
It's tubbed front. What's the max size inner barrel yall think I could run? My friend has some equips I want and they are 17x10.5 0 with 6.5" inner barrels. I know there's a lot of variables but it's 2am so yolo Copy pasta suspension mods for reference Fortune Auto 500 Series Coilovers with 10k/9k swift springs, rebuilt in 2011 with very little miles on them -Parts Shop Max front and rear Knuckles with Wilwood rear e-brake calipers - Ikeya Formula inner tie rods with tien outer tie rods - Modified front and rear lower control arms with custom roll center adjusters utilizing 3/4" spherical bearings and Chevy circle track ball joint shanks (I have extra parts for these as well) -Fortune Auto tension rods, traction arms, and toe arms
loading HATERS.....99% ███████████████] |
