Old 06-26-2018, 09:30 PM   #1
Sr20-Vert
Sr20-Vert's Avatar
Sr20-Vert is a well-known jackass
Need help on cluster light and tail lights not working
Fellow Zilvia memebers I need some help I tried searching not really sure if I am typing right thing but my tail lights and cluster lights don’t work brake lights are fine I herd there is a white box mybee fuse some where if someone can help Greatly appreciated
Sr20-Vert is offline   Reply With Quote
Old 06-26-2018, 11:41 PM   #2
Sr20-Vert
Sr20-Vert's Avatar
Update fuse is good does anyone know the wire that controls this Mybee I can Splice it somewhere else
Old 06-27-2018, 05:38 AM   #3
KoukiMonsta
KoukiMonsta's Avatar
bust out the FSM and look for light circuit, hint - EL section. 'lights' and cluster lights are all on the same circuit, Red/Blue wire from COMBI SW to Fr and RR lights.
Do you have power at the switch?
Do you have power at the fuse?
how the heck can we magically figure out whats wrong.
@UpshiftEngineering
Old 06-27-2018, 10:18 AM   #4
Sr20-Vert
Sr20-Vert's Avatar
Ok I checked fuse has no power to fuse at all . Any idea what wire does this ?
Old 07-07-2018, 11:33 AM   #5
sig jr.'s cousin
sig jr.'s cousin is an unknown quantity at this point
It's in the turn signal stock. Disassemble the dash to get to it. And there is gonna be 5 copper strips on the stock and the middle one controls the cluster and rear lights. I pushed mine in a little and it works but over bumps it sometimes turns off.
sig jr.'s cousin is offline   Reply With Quote
Old 07-18-2018, 10:16 PM   #6
Olyptorius
Olyptorius's Avatar
Olyptorius is an unknown quantity at this point
Did you check the 75amp fuse in engine bay? Also the white box under dash controls cluster lights. This may be your culprit.
Sent from my iPhone using Tapatalk Pro
Olyptorius is offline   Reply With Quote
Old 07-18-2018, 10:32 PM   #7
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
i have the 75 amp fuse if yours is bad
