Old 12-25-2015, 07:35 PM   #18961
KAT-PWR
KAT-PWR's Avatar
88 rotors sells a rotor that is drilled for 4 and 5 lug. That's what I ran
MRP Manufacturing
Old 12-25-2015, 09:01 PM   #18962
AnonymousBlackX
AnonymousBlackX's Avatar
AnonymousBlackX is an unknown quantity at this point
Yup did the same
My 240
youtube.com/AnonymousBlackX
AnonymousBlackX is offline   Reply With Quote
Old 12-26-2015, 06:13 AM   #18963
Konster
Konster's Avatar
Konster is an unknown quantity at this point
A few years back I saw a S13 carbon fiber door, I forget with company it was, they were giving it away if someone guessed the correct weight, anyway on to my question. The door handle looked like the handles you see on Murano's. Anyone know anything about that?
Hyer.
Konster is offline   Reply With Quote
Old 12-26-2015, 01:39 PM   #18964
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
I am not sure if this was asked before or not, but if it was, I'm sorry.
Is it just me or does anyone else suffer from the rubber feet on hood taking of some paint on the 'shock tower'?
It seems to be a hard material that rubbed the paint off.
Are there any softer replacements or do I have to keep repainting that spot (which is very annoying)?
SoundEfx is offline   Reply With Quote
Old 12-26-2015, 03:34 PM   #18965
Corbic
Corbic's Avatar
Is there a part number or US part for the SR20det CAS cover gasket?
Changed out the trigger wheel and the gasket is a stretched out 25 year old hot mess. Shit looks like Miley Cirrus's underside.
Old 12-27-2015, 01:03 AM   #18966
chato de shamrock
chato de shamrock's Avatar
chato de shamrock is an unknown quantity at this point
Two questions
Ive noticed over the years that the doors on my 240 crack and screech whenever winter rolls along. Living in L.A. I've used white grease to lube them up and it seems to be a decent temporary fix. However, now that I moved to the south the winters are colder and im wonder what you 240 owners from the east coast and southern states do to keep your car's hinges from making noise, especially in the winter time?
Also been wondering what's a good PSI i should have my tires inflated on. They are 225-40-18 on an 18x9. How do you folks come about finding the proper inflated level for your tires?
Thanks in advanced.
chato de shamrock is offline   Reply With Quote
Old 12-27-2015, 09:37 AM   #18967
newkid99
newkid99 is an unknown quantity at this point
^wd 40 seems to work best for me. Any way I've got a question about a ka24de throw out bearing. I bought this one on ebay:
do those prongs on the side grab the fork and remove the need to press in the piece on the right like on the oem bearings?
I don't have alot of faith in this one because it was the cheapest on ebay. I am also going for 400+ hp so I may just go back and buy an oem one.
newkid99 is offline   Reply With Quote
Old 12-27-2015, 10:49 AM   #18968
SoundEfx
SoundEfx's Avatar
Thanks in advanced.
The proper tire psi should be written on the tires.
Old 12-28-2015, 02:56 AM   #18969
LI NY 240sx
LI NY 240sx's Avatar
LI NY 240sx is an unknown quantity at this point
Nope. You inflate the tires as per the vehicle, not the tire. The pressure listed on the tire is the maximum pressure the tire is rated for.
The correct tire pressure is usually listed in the glovebox or in the drivers door jamb. Remember that it is for stock wheel and tire sizes.
LI NY 240sx is offline   Reply With Quote
Old 12-28-2015, 11:09 AM   #18970
I'm Redline
I'm Redline's Avatar
Thanks in advanced.
Q1: I use synthetic Silkolene red grease for my rifles and my doors. It stays in place, and does not melt in the heat
Q2: Tires should be ran at 35psi, BUT, PAY ATTENTION NOW, if your car shows uneven wear in the center, drop to 30psi. If it shows wear on the outer edge, jump up to 40psi.
Just becuase the tire says max pressure is 44psi, does not mean you use that. In the case of a 240, you will wear your tires with an overeinflation pattern
My work in progress...
Old 12-28-2015, 11:09 AM   #18971
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Does anyone know if there is a specific part number for the ebrake spring? Or is it a universal type spring? Either way, I need some specs. If you could provide a link thatd be great too
DJTTon is offline   Reply With Quote
Old 12-28-2015, 05:21 PM   #18972
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Rear exhaust hanger how to reuse it
So I installed my rear bash bar, removing the oem rear bash bar obviously. My question is how to I reuse the exhaust bracket, I'm pretty sure it'll have to be custom right ? Pictures with anyone having a custom setup would be greatly appreciated as I am trying not to use a wire hanger to support the tip of my exhaust. Pm me please
S-Nation S13 is offline   Reply With Quote
Old 12-29-2015, 12:26 PM   #18973
Turb
Turb's Avatar
Turb is an unknown quantity at this point
Power loss problems?
So was sliding my sr20 swapped s13 coupe and out of no where I felt a sudden loss in power, car boosts fine, idles fine. But sounds like a lawnmower so i thought I would compression test it and I have everything hooked up fine but my compression gauge is like falling. pretty much it seems to build compression fine but losses compression. Seems like I'm blowing up a balloon that has a hole in it. What do you guys think?
Turb is offline   Reply With Quote
Old 12-29-2015, 03:58 PM   #18974
DJTTon
DJTTon's Avatar
Bought a shifter bezel for real cheap, didnt realize that the boot is held in place by the plastic prongs that stick out on the bottom. Long story short theyre all busted and I have no way of attaching the bottom trim.
Was thinking of just drilling 5 holes that line up with the trim and holding it with 5 screws.
Anyone have any other ideas or experience before I do this?
Old 12-31-2015, 01:28 AM   #18975
Reece
Reece's Avatar
Reece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymore
This isn't S chassis related but it's really annoying me.
I replaced the right rear brake caliper on my Protege the other day.
At first, the handbrake didn't work at all. But I've noticed it's slowly getting back to normal and engaging like it should.
.. Why? I've done rear brakes on lots of my other cars and this never happened? Not really a big deal but it's really weird.
Originally Posted by Almighty So View Post
Don’t price bash me.
Reece is offline   Reply With Quote
Old 01-03-2016, 12:50 AM   #18976
Razi
Razi is an unknown quantity at this point
Weird question:
Does your S13's ashtray light, light up very dimly if you adjust your side mirrors?
I didn't notice this until I took my ashtray out and I was fiddling with the mirror switch.
So fucking weird.
Razi is offline   Reply With Quote
Old 01-03-2016, 01:15 AM   #18977
AnonymousBlackX
Originally Posted by Razi View Post
Weird question:
So fucking weird.
No
(Minimum for post)
My 240
Old 01-03-2016, 08:42 AM   #18978
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
Is it a screw and nut style parking brake integrated into the brake caliper? They must be adjusted after maintenance. To adjust them, repeatedly apply and release the parking brake. The self-adjusting spring in the caliper will keep them adjusted correctly.
dbeiler is offline   Reply With Quote
Old 01-03-2016, 08:46 AM   #18979
dbeiler
dbeiler's Avatar
I use motorcycle chain lube. No more problems, ever.
Old 01-03-2016, 06:02 PM   #18980
DJTTon
DJTTon's Avatar
Does anyone know where I can get a NRG qr steering wheel hub? The assembly comes in two parts the part that mounts to the steering column and the other that mounts to the steering wheel. Im looking for the part that mounts to the steering wheel.
Old 01-03-2016, 10:53 PM   #18981
DJTTon
DJTTon's Avatar
Can someone comment on whether 225 is a decent price on KA24DE eagle rods?
Old 01-04-2016, 04:30 AM   #18982
Corbic
Corbic's Avatar
Yes. Retail is $400.
Old 01-04-2016, 08:26 AM   #18983
I'm Redline
Fuck NRG and their shit. Get a Bell Works Hub. All teh NRG guys told me that their shit worked with the 240 horn which was pure lies. When I finally got to the one tech who told the truth at Enjuku, he said straight up, 'THE only adapter and QD that works with your 240 horn is WORKS BELL. Buy once, cry once, but it's the best out there" This was also verified with one call to Touge Factory who also said the only one that works is Works bell
How far do the lies from NRG spread? From Peter Lee who sells that shit here, all the way to the top techs(unless they fired them and told them to tell the truth).
Go through Touge Facotory or Enjuku and get a Works Bell adapter and QD, you will be a lot happier
Did I say Fuck NRG's adapters yet?
Old 01-04-2016, 08:29 AM   #18984
Corbic
Corbic's Avatar
All cause you couldn't get your horn to work?
Old 01-04-2016, 09:37 AM   #18985
DJTTon
DJTTon's Avatar
Sometimes you just gotta toot your own horn, so I understand
Old 01-04-2016, 09:57 AM   #18986
DJTTon
DJTTon's Avatar
I could get the boss short hub but still use the NRG quick release? Is that possible?
Old 01-04-2016, 03:34 PM   #18987
Eduardo Miranda
Eduardo Miranda is an unknown quantity at this point
Is anyone selling a zenki passenger headlight? Really need one
Eduardo Miranda is offline   Reply With Quote
Old 01-04-2016, 04:43 PM   #18988
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
did you try the for sale section? just sayin...
Old 01-04-2016, 08:51 PM   #18989
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Maybe get a small piece of 'closely' colored vinyl and attach it there? Or even clear vinyl?
Gonna be custom. Not hard to make yourself either, you can get universal hangers and then use a bolt up up in the frame/get fancy with it. Or take it to a muffler shop and make it fancy
Get another gauge and try again. It should hold due to the check valve in the gauge.
Any codes?
Any vacuum leaks?
How do the plugs look?
Verified fuel/spark?
Boot or the trim piece itself? You could probably glue the shift boot part up to the trim piece
Old 01-04-2016, 08:51 PM   #18990
codyace
codyace's Avatar
Trader Rating: (58)
Being a remanned caliper, it's hard to say what is in side of it, or how well the mechanism was fixed.
