09-02-2010, 06:33 PM | #1 |
FT 1996 nissan 240sx SR20DET w/extras
i guess you could say im testing waters on my car. if i hear something i like i will jump on it though
looking to trade more then anything, i have no use for money but i will take it if need be. or we can do trade plus cash depending on circumstances. looking for something else thats sporty, just let me know what you got and what your willing to do as far as trade. 1996 nissan 240sx sr20det (redtop) pearl white with black rims Location: killeen texas Power locks and windows (it is in working condition) sunroof also has an alarm that has been disconnected due to wiring issues a while back, but im working on putting that back in motor was rebuilt from maximum velocity in San Antonio CP pistons 87mm Eagle con rods forged crank all brand new when the motor was put in 2 years ago. I have the receipt from the rebuild also brian crower stage 2 camshafts hks rocker arm stoppers ARP Head Studs Cometic Metal Headgasket rebuilt head with new OEM parts brand new wiring harness just put in about 3 months ago (dont have to worry about that) Greddy TD-06 20G turbo (rebuilt in 2008 have reciept) Internal Wastegate at 10 PSI Tpros Headers greddy BOV OBX FMIC ISIS radiator Samco Radiator hoses ISIS Intake Manifold Greddy Oil pan Walbro 255 Fuel pump oil cooler new thermostat put in last year stock 370cc injectors sr20det MAFS Spec stage 3 clutch toda flywheel does have power steering No A/C NGK iridium spark plugs boost guage AEM Air Fuel Ratio Wideband 3" downpipe CatConverter (I have a test pipe that I will throw in or I will just put in on myself in the future) Apexi Dual N1 exhaust Comes with a CD deck but you cant take the CD out. Radio works though and you can listen to T.I. Paper Trail lol exterior is in excellent condition minus the radio bezel that cracks like all the time It is a 5 lug with the original factory rims just painted black tires are still in good condition battery relocated to the back exterior is in decent condition, bodykit could use a rebuild. and someone tried to break in the passenger side using a crowbar. upgrade 300zx front rotors and calipers new rear pads and rotors front stainless steel brake lines (for the conversion) car has been lowered with lowering springs also have an oil catch can and strut bar. and a fiberglass wing i can put on for you The bad: Transmission might need a rebuild and the car will need a tune due to the cams and larger turbo The car still drives strong, you just cant push the car while in 1st Gear because when you shift from 1st to 2nd it will grind Only when your trying to be speed racer though. Will not happen under normal driving. PM me and thanks for looking |
240sx, nissan, sr20det |
