09-18-2017, 04:12 PM | #1 |
1989 Silvia S13 1JZ $9K obo
I'm selling my 1989 Nissan 240SX Silvia drift car . The car has a clean title and is currently registered as non op due to it being a full time drift car. The car starts and runs great. the following list of parts are currently installed on the car.
89 Nissan 240SX Coupe with Silvia front end with Brick Headlights extreme dimensions body kit 40mm front fenders 40mm rear over fenders vented fiberglass hood Top Drift Legal Cage built by Martin at Parts Shop Max in San Diego 1JZ GTE non VVTI R154 5 speed trans with new seals wiring specialties 1jz wiring harness Spec stage 3 clutch xcessive one piece drive shaft xcessive motor mounts and trans mount sikky front sway bar front and rear drift armor bash bars Parts Shop Max Coil overs Parts Shop Max solid sub frame bushings Parts Shop Max rear lower control arm Parts Shop Max camber arm, toe arm and traction arm Parts Shop Max rear drop knuckle with dual Z32 calipers Parts Shop Max pro front lower control arm, tension arm combo bent type Parts Shop Max front super angle drop knuckle Parts Shop Max spherical bearing crmo inner tie rod Parts Shop Max rack to inner tie rod mount offset Parts Shop Max steering rack eccentric bushing Parts Shop Max high mount intercooler Parts Shop Max hydraulic hand brake with independent z32 caliper Parts Shop Max breather tank Parts Shop Max evdm gauge Parts Shop Max remote oil cooler filter relocater 26mm front z32 caliper and z32 rear caliper 5 lug setup Tial Q bov Helical lsd walbro 255 fuel pump mishimoto radiator and fan setup 2 sparco evoII plus replica seats 2 crow 5 point restraints sparco deep dish steering wheel with quick release arc push button setup for turing on the car, lights and fans 17x9 front enkei rpf1 with falken azenis 18x9.5 rear varostoen wheels with federal tires used the rear fender has been zip tied together due to me hitting cones at willow, if you have any questions please email and ill do my best to answer them. I'm asking 8,000 or best offer or trade.i don't have the time anymore to be trailering up to the track as much as i would like to. thanks Last edited by slidestyle180sx; 10-07-2017 at 09:54 PM.. Reason: Price drop |
