09-26-2017, 02:38 PM | #31 |
yup no engine is above those symptoms if it gets bad enough. I'm going to assume in my situation there has to be a very small leak. I drove the car today but it was raining so i didn't even get into boost at all. Normally for it to creep up to 210F+ it takes about a 10min drive which is about how much i drove it today. Without getting into boost it didn't even get hot. When I was on my street right before I got home i got into boost one time and the gauge went from 185F to 200F just like that so there has to be a small leak in the HG. Still want to do a leakdown test to confirm that 100% though.
09-29-2017, 02:57 PM | #32 |
Hydrocarbon test will confirm a blown head gasket.
10-04-2017, 09:07 PM | #33 |
10-19-2017, 10:35 PM | #34 |
The answers to your questions have been stated.
I had the same problem when I did my very first SR. Isis aluminum radiator, Mishimoto dual 12” e-fans. Overheated exactly as you’re describing, and got even worse going up hill. I thought it was a blown HG until I realized that e-fans are fucking retarded. Buy a OEM clutch fan and a fan shroud for <$100 and ditch the e-fans. Don’t skip out on the shroud because the fan won’t do anything without ducting. Sent from my iPhone using Tapatalk |
10-20-2017, 08:27 AM | #35 |
if you get quality e fans and properly wire in a relay its fine...most people skimp on the relay and fans and think its ok...Altima fans are good...autozone/oriellys 30$ special are not...
10-20-2017, 09:00 AM | #36 | |
I believe Mishimoto is quite good and reputable. Either way, nothing will beat the stock clutch fan. Keeps my SR around 70 Celsius even on hot ass days. Sent from my iPhone using Tapatalk |
10-21-2017, 12:00 PM | #37 | |
As a plus if you get the N-flo from koyo you get a triple pass rad which is sweet. You are definitely right that if you want good cooling keep a clutch fan and oe shroud. That's what I try and tell most people. Unfortunately the clutch fan wouldn't work in my application so the taurus fan is what I use now after using the mishimoto fans and shroud... |
10-21-2017, 12:52 PM | #38 |
clutch fan is what keeps my rb cool even in the hottest days here in TX. LOve to hear that thing hum after a spirited drive! I am now planning on building a shroud for it.
Tuners are big bullies |
10-21-2017, 01:03 PM | #39 | |
+1 for the clutch fan on RB Schassis. What shroud are you using to modify? I was planning on trying a R33 GTST one... not sure yet though |
10-21-2017, 07:00 PM | #40 | |
I found a mecedes 500 sec that has a very slim shroud and the radiator is around the same dimensions. I might have to buy that one to experiment with. The only problem is that the actual fan blade hole is too centered, whereas the rb's sits more towards the passenger (usdm) side. I also did a search on "500 sec fan shroud" and it shows two different kind of shrouds, the one that I saw, and another one with the blade hole a little offset, so I might have to look into that.
10-21-2017, 07:04 PM | #41 | |
That’s very interesting. Let me know what you end up doing! Gonna need a good ducting setup this summer for my RB. |
10-22-2017, 05:00 PM | #42 | |
10-22-2017, 06:30 PM | #44 |
10-22-2017, 06:32 PM | #45 |
10-22-2017, 06:39 PM | #46 | |
Ive got a circuit sports fan controller and im seeing temps for a short drive 15-20 to work I get to around 84c(183) regularlly on my drive to work in the morning. Then when I go to school about 10 miles away taking mostly I highway I hit 90-94c(194-201f) always and if Im driving a lot it will creep up to 95-97. Also noticed if I drive and let it cool down then go to start it sorta like when I go out to our meets, hang out for a few hours and start the car but dont turn on the fan once it hits OP temp at 70-74c I will wait a bit and my temp gauge on the cluster is reading fairly hot and my gauge looks to be lagging behind. I did notice im not getting a reading on one of my probes for my fan controller. So could be my temp for oil is 194-201f which is normal for oil being 10-20 degrees warm than coolant or maybe my oil temp gauge got damage when I replaced the filter recently... The wires are so brittle. First I'll see which sensor im reading, switch to water wetter and distilled instead of 50/50 mix and get one of those coolant funnels since i've herd good things about those. |
10-22-2017, 06:39 PM | #47 |
roger that, i commented on it so i can view it later on. Should be starting a new job here pretty soon so if you have it in a few weeks won't mind buying it once i get the money.
10-22-2017, 06:42 PM | #48 | |
Sounds good. My number is on the ad contact me whenever you’re ready to purchase Sent from my iPhone using Tapatalk |
10-22-2017, 09:18 PM | #49 |
