08-08-2018, 07:01 PM | #1 |
Found plastic shards in oil pan
Well guys heres pictures. I have ZERO idea what it is and where it came from
There was small ones in pickup but im sure only some made it through the screen Am i fucked what do i do i havent pulled timing cover and valve cover yet. Car wouldnt idle previous to this, i rebuilt it and timed it wrong so i pulled it again and this is the first thing i find out. What in the hell Sent from my iPhone using Tapatalk |
08-08-2018, 07:12 PM | #2 |
Thats a timing chain guide. I'd suggest against trying to start or turn the engine over by hand since you timing chain probably has no tension on it currently. I've never seen this happen before, post pics of what it looks like once you get the front cover off. Best case scenario, you replace it and are good to go, worst case you bent valves and damaged pistons...
08-08-2018, 07:25 PM | #5 |
yup, def timing chain guide.
google search the fsm, buy the part online (rockauto, etc) and get it fixed.
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
08-08-2018, 07:44 PM | #6 | |
Pull the front cover and inspect before you do anything, I'd also pull the cams out at minimum to make sure all of the valves are returning properly and do a visual inspection into the intake and exhaust ports at bare minimum before you throw a new guide in and hope for the best.
08-08-2018, 08:22 PM | #7 |
As suspected, was a timing guide. Guess when your 17 doing shit like this you have to learn the hard way not to cheap out on an ebay timing kit Never again am i buying ebay shit for my motor lol. So. I plan on ordering new tensioner. Replacing that and re timing it with a stock intake cam ( i have dual exhaust cam bs from previous owner which made it hell to try and time it. I think im going to send it and pray a valves not damaged. I dont have the money to have it rebuilt AGAIN for the head and dont want to bug my dad for $200 to get the head rebuilt with valves or have a shop inspect it. Sound like a good plan? ^^ Thanks for help guys Sent from my iPhone using Tapatalk |
08-08-2018, 08:33 PM | #8 |
I had assumed it was an SR, but since its a KA you might be okay. I say go for it, use OE parts this time and see how it goes.
08-09-2018, 08:05 AM | #9 |
I left out the top chain guide on my rebuilt KA, from what i've read on this forum it only causes problems (breaks and falls into you pan like you've seen) . I've been running without the top chain guide for awhile now without issue
