06-04-2012, 07:50 PM | #1 |
FS: 1996 Nissan 240SX SE (S14) T25 KA24DET
I really don't want to sell my fun car as I've really put a lot of time into it and love driving it, but I'm moving out of state. Car was set-up more for autocross and HPDE, but it could be converted to drift as well. Engine runs and idles great. I have used the car as a daily this spring and summer.
Color = blueish green. Good body. De-badged. Clean stock interior. Aftermarket sunroof. Mileage = 144K. 5-speed manual transmission. Garrett T25 turbo from S13 SR20DET Sidemount intercooler from S13 SR20DET 370cc fuel injectors from S13 SR20DET Supra blowoff valve CX racing sidemount intercooler pipes Aftermarket open air intake Stainless steel oil feed and return lines Glowshift oil sandwich plate Innovate LC-1 wideband O2 sensor + gauge Autometer boost gauge Ebay turbo manifold Ebay divorced turbo outlet + 3" downpipe Custom 3" exhaust with cat removed 300ZX fuel filter EFI Specialists ECU tune on factory OBD1 ECU Fidanza lighweight flywheel Spec stage 2 clutch KYB AGX shocks/springs + RSR race lowering springs + HKS camber plates 350Z 18" touring rims painted gunmetal with Nitto fronts and brand new rears Conti Extreme Contact DW New front outer tie rod ends, New front and rear sway bar end links, New rear brake pads, New wiper blades/rubber, Fresh oil change + filter Valvoline synthetic brake fluid Infiniti J30 VLSD with Redline Fluid Energy Suspensions poly subframe bushings SPC adjustable arms for rear traction links, toe links, rear upper control arms, and front tension control rods Ichiba 15mm bolt-on front spacers I may be forgetting some items. I'll try to remember the other modifications. Car will come with stock rims and many extra stock parts. I need to clean out the garage. Minor issues = door/trunk locks don't match ignition and don't have key. Slight dings/dents + minor surface rust (This is not a show car, but the body is pretty good for a Midwest car). Clutch needs bled. Price = $5500 OBO. No trades as I need to reduce my number of cars. PM me to set-up a test drive or to discuss over the phone. I will not discuss price over email/PM.
96 S14 SE with T25 KA24DET |
06-05-2012, 06:56 PM | #2 |
Car will come with stock rims, stock springs/dampers, stock open diff, stock suspension arms, stock ECU, stock fuel injectors, extra open air intake, and probably more. Let me know if anyone is interested. Thanks.
06-06-2012, 06:20 PM | #5 |
I think I should clarify this. I'm not taking anything off the car. The car will come with all the stock parts too if the next owner wants to Go back to a na motor setup.
240sx, ka24det, kat, s14 |
