07-20-2017, 07:09 AM | #1 |
Intermittent Vibration Help
Technical question for an intermittent problem, I'm a bit stumped. After driving on the interstate a while, the car starts shaking and steering wheel will vibrate like a tire is out of balance. It's not tires because it would be constant. Also while this is going on, I've noticed the brakes are hard, like tapping them is like slamming the brakes, pretty much an on/off switch. While cold, they feel fine, and not every time either. Yesterday going to work was crazy, coming home was fine.
Front suspension has been replaced, including shocks, outer tie rods and ball joints. I've triple checked lug nuts. I'm suspecting inner tie rods, some bushings, or something is up with the brakes. This is an S14 with Z32 brakes all around. |
07-20-2017, 08:33 AM | #4 | |
GM2 (SW/AW)
So it sounds like you've done just about everything with exception to your bearings.
Have you had the front end in the air to check them?
KA-T for life! Current for sale advertisement |
07-20-2017, 11:55 AM | #7 | |
Still have stock S14 15/16 master cylinder. Have a brand new 1" Z32 MC, just haven't installed it in the 3 years it's been sitting in my garage, lol. I hate intermittent issues. |
07-20-2017, 12:10 PM | #8 |
From my understanding about the z32 brakes, you need to change out the BMC since you're running all 4. Stock MC is fine if you had front z32 only; if the car was changed from auto to manual, the auto brake booster will make your brakes very sensitive compared to 5-speed factory (auto brake booster is larger than manual).
I understand you said that tires cannot be an issue but if your wheel is not balanced, this will also cause your wheel to shake at "certain" speeds. Here's the info about the brake booster/Master cylinder I am referring to: http://importnut.net/300zxbrakeswap.htm#MC (old) http://importnut.net/the-definitive-...cylinder-swap/ (New Version) Lastly, inner tie rods fail and in order for you check is it jack up your car, remove the other tie rod from the knuckle and see if there's play when you push/pull the tie rod (best way is to get the steering to lock if you're working by yourself).
07-20-2017, 02:12 PM | #10 |
Trader Rating: (130)
Feedback Score: 130 reviews
[QUOTE=1on1;6215235]From my understanding about the z32 brakes, you need to change out the BMC since you're running all 4. Stock MC is fine if you had front z32 only; if the car was changed from auto to manual, the auto brake booster will make your brakes very sensitive compared to 5-speed factory (auto brake booster is larger than manual).
QUOTE] you don't HAVE to change to z32 master, but its an improvement, since the z32 master is sized for those calipers. Running a 240 master with z32 calipers works just fine, but the pedal feel is better with z32 master. OP, does your car have ABS? is the ABS light on? |
07-20-2017, 03:11 PM | #11 | |
I'll inspect brake lines and try to check for play in the tie rods tonight. Also check for uneven pad wear in case brakes are messed up. |
07-20-2017, 03:34 PM | #12 |
check all tires for feathering or signs of flat spots or tread separation or bubble in the sidewall
07-21-2017, 03:56 PM | #14 |
My car shook like hell 40-45 mph and only in that speed range. got my front tires balanced and that was the end of it.
id highly recommend checking your wheel bearings and chassis components for play. this is likely and alignment/tire balancing issue
The Game you lose haha |
