11-07-2016, 11:38 AM | #1 |
Engine(ka24de) is overheating
My engine started to overheat, the overflow tank smelled a little bit like gas and bubbles were coming out so I figured it would be a head gasket. So I went on and replaced it. After replacing it no more gas smell or bubbles but engine still over heats. Bought a water pump, clutch fan, thermostat and replaced them. But the engine still overheats. Last owner changed the radiator because it looks new so i dont think its the radiator or heater core because heat works. Anything else that would cause a engine to overheat?
11-27-2016, 09:13 PM | #2 | |
11-27-2016, 09:39 PM | #3 | |
11-30-2016, 03:03 PM | #5 |
I've had my ka-t overheating from pushing coolant out of the overflow. Also thought it was a head gasket, but issue still remained after replacing it. The real cause was the mishimoto radiator cap that came with the radiator. They're notoriously shitty. Threw on a blitz cap and it's been happy ever since.
12-07-2016, 12:00 PM | #6 |
did you check the flatness of the cylinderhead when you changed the gasket? If you've overheated in the past there is a good chance its warped now, A replacement headgasket cant seal a warped head.
Does the engine push all your coolant out? can you see a smoke coming off your coolant |
12-07-2016, 05:15 PM | #8 |
Had this same problem last year. Ended up being the shit radiator cap I had on the DNA Motoring Radiator or whatever it is. HKS Cap on it, haven't had a problem since. Would run a Nismo Thermo if funds allowed, but since everything is new, no point in changing one.
Bleeding should be, jack up front of car (so it is highest point) fill up radiator with the bleeder screw open until a stream of coolant flows out. Put the bleeder bolt back in. Run the motor with the radiator cap open and like a 2 liter bottle of soda in the filler neck with a few runs of electrical tape around it. Fill it until it's like a quarter full. Run the motor for like 15 minutes and burp the system. Squeeze the hoses a few times if necessary. You may have to do it 2 or 3 times but you'll get it. KA's trap so much air, so annoying to bleed but it can be done. |
