01-14-2015, 12:05 PM | #31 | |
The ecu has all the spark and ignition drivers in it. The ecu will work on ground terminals. The ecu based on the cas will tell the ecu where the crank is and then fire the correct spark plug. If you put enough power through the harness and your fuse doesn't blow, the voltage will travel to the ecu and burn out your ignition drivers. Don't do all this stupid chasing around. Try a new ecu and come back with results. Your wiring loom unless its hack to hell is fine.
Turn and Burn! |
01-15-2015, 10:59 PM | #32 |
Wiring/ starting issues
A new ecu isn't the easiest thing given the swap. Have to find one that matches the current then send it for NATS Removal. That being the case I'm trying to eliminate all else before doing that.
I did get it to start and run for about 10 seconds before it died on me however I had to hold the key in the start position for about 20 seconds. Battery is now so dead it won't jump start. Only get fast starter clicks. Of course I didn't have a code scanner with me and battery was dead by the time I got back. Was hoping those 10 seconds would give me a code. Last edited by nddavis2; 01-16-2015 at 04:24 AM.. |
01-16-2015, 10:23 AM | #33 |
Ugh.... I feel for you man. That sucks....
So just reiterating what you said. Fuel pump turns on. Starter Cranks Only problem is spark. Which you are saying it works when you hold the ignition in start position? I thought you weren't getting any spark?
Turn and Burn! |
01-16-2015, 10:55 AM | #34 |
That's part of where I realized I hadn't updated the post completely.
Fuel pump turns on, starter cranks. Actually got it to start 1 time and run for about 10 seconds and then it died. Haven't been able to get it to start since. I need to remove the coils and check to visually verify I have spark which I will do tomorrow |
01-16-2015, 11:09 AM | #35 | |
Turn and Burn! |
01-16-2015, 11:19 AM | #36 |
Thanks. When I check it tomorrow I'll repost on here what I find. I really need to replace the harness. I'd love to just have one made but those sucker are crazy expensive
01-18-2015, 11:41 AM | #37 |
Not going to be able to check spark for a few more days. Need help on the 350z harness.n3 plugs I have no home for.
Has yellow/ red wire and orange wire and runs near the back of the engine Blue/ green I think the single wire is. Located near the maf plug Don't have a pic of the 3rd but it's basically same as the first but has a light brown/ yellow wire and black. Just need to know what these should go to on the vq as it could be part of my issues. |
