10-12-2013, 04:42 PM | #1 |
Wiring up starter?
Working on my VH45 swap wiring. I've got a cable running from the positive on my battery to the starter solenoid, then the yellow/black trigger wire is connected to the fuse block like it should, but I'm left with these:
I know they are a part of the starting system, but I don't have anything to plug them into. Everything else is hooked up correctly to the starter and alternator, just left with these. |
10-15-2013, 10:42 PM | #3 |
Those are your main power plugs that will supply power to your fuze box. They would normally plug into your transmission harness where it connects to the battery. I will try to post a picture tomorrow if you need a better explanation with a picture.
