Old 05-31-2018, 02:38 PM   #1
chrisbmx68
chrisbmx68 is an unknown quantity at this point
FS: 1991 white e30 318is slicktop sr20det swap
$12k for everything but the teal wheels
Trades also welcome if you have a gen 1 cts-v, e39 m5, e90/92 335i 4 door manual, 4 door mk6/7 gti-tdi, 3.2l a3, b5 s4's
somewhere around 295k on the body its on its 3rd set of odometer gears
rust free
no ac no ps
body and paint is good for the age but isn't perfect. Has a couple dents and imperfections
Walk around video https://flic.kr/p/261pVjR
Dyno video https://flic.kr/p/27iXQJm
2nd to 4th gear pull video https://flic.kr/p/27o4Q6a
385whp and 366tq at 19-20 psi
Engine
Nissan Sr20det black top
Tubular top mount t3/t4 manifold
Greddy td06 20g turbo
Nismo 740cc injectors
Z32 maf
Rs enthalpy tuned #62 ecu
Innovate wideband o2 sensor and gauge
Z4 manual steering rack
Porsche 944 brake booster
Os giken super single clutch, with billet ¾ slave cyl
ATI Super Damper Crank Pulley
Nismo clutch pivot ball
Spal radiator fan + aluminum e36 radiator and custom overflow tank
Wiring specialties sr20 swap wiring harness
Powder coated valve cover with welded on -12an breather
I have tomei procams and arp head studs that I haven’t had a chance to install yet
Suspension/drivetrain
Megan racing coilovers/camber plates height and dampening adjustable 6k front 8k rear
Modified reinforced race skids skid plate
E30 convertible inner fender and strut tower weld in reinforcement panels
Stainless front strut bar
Sparco rear strut bar + rear strut tower reinforcement plates
z3m style reinforced rear control arms with welded in bracing
Stainless brake lines
Poly 12mm raised rear subframe bushings with new oem rubber rtabs and subframe adjusters welded in
3.73lsd with e36 dual ear rear diff cover and welded in bracketry
Custom one piece driveshaft with billet e30 rear yolk and serviceable 1310 u joints from shaftmasters
Front subframe motor mount reinforcements welded in
Ultra racing 4 point lower subframe brace
Delrin non offset front control arm lollipop bushings
Interior
Black leather vintage 80s Recaro front seats
Momo mod 69 suede steering wheel
Alpine radio with ipod control
Exterior
Projector headlights with 4300k hid’s (I also have led’s and drivers I can include)
Euro bumper trim (deleted side markers)
Smoked front turns
Fog light deletes (turbo intake is in the way of running fogs; I have fogs I can include)
Mtech 1 wing, is front lip, and side skirts
It’s a 1991 so shadowline window trim was stock along with power antenna which has a new grommet
Wheels
Stock 14 weaves with older all seasons good for dd status, winter or whatever
Freshly powdercoated 15x7.5 kosei k1’s using 20mm spacers in front and 25mm in back and wheel studs they are Honda/vw offset 195x50 tires
Super rare (only set I know of in existence) wrd/hayashi 3 piece wheels 16x8 et 10ish rebuilt resealed straightened and powdercoated candy teal. Replacement custom center caps were lathed and nuts sourced from HRE $$$$ 205x45 tires (For asking price I will include all the extra center cap pieces I have gathered)
Extras
Two Rubbermaid containers full of misc. e30 and sr20 parts
tomei procams, and arp head studs
Thule rack with hard to find 555 fairing and bike and ski carriers
chrisbmx68 is offline   Reply With Quote
Old 06-02-2018, 08:18 AM   #2
MandTPhotography
MandTPhotography is an unknown quantity at this point
GLWS dude, this thing is titties.
Your video links don't work BTW.
MandTPhotography is offline   Reply With Quote
Old 06-03-2018, 07:58 AM   #3
chrisbmx68
Thanks its going to be sad to see it go. The links seem like they load on the pc fine but not on mobile for some reason. ill try to host them somewhere else.
Old 06-12-2018, 10:52 PM   #4
Konster
Konster's Avatar
Konster is an unknown quantity at this point
This thing is fucking dope.
Hyer.
Konster is offline   Reply With Quote
Old 06-15-2018, 04:31 PM   #5
Plan.B
Plan.B is an unknown quantity at this point
How low does that oil pan hang down?
Plan.B is offline   Reply With Quote
Old 06-15-2018, 05:22 PM   #6
chrisbmx68
Fairly low but not crazy. I'm able to use the same skid plate I did with the m50 and m42 this car had previously. It's reinforced and the lower apron of the car is a 2x3 box tube welded in as the front support for the skid plate.
Old 06-21-2018, 02:46 PM   #7
chrisbmx68
Price update 12k with everything but the teal wheels and 11k on the stock weaves.
