10-31-2003, 05:18 PM | #1 |
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
how to install an oil pressure gauge on SR
subject explains it all, im not so sure where to screw the thing into, any ideas?
thanks -Jeff
89 240 SR powered... ummm i promise its stock |
11-01-2003, 04:39 PM | #2 |
If you have access to a welder the easiest way would be to pop a hole in the oil pan and weld a nut with matching thread to the pan. Just make sure that you double check the clearences so you don't get interference between the oil pickup and sender unit when you go to put the pan back on.
Don't pick fights with ugly people, they have nothing to lose... |
11-01-2003, 04:42 PM | #3 |
Sorry, just realized you said oil pressure sensor, not temperature sensor. The SR has a stock pressure sensor. I believe you can tap into it's signal(so long as you have an electric gauge), but don't quote me on that.
11-02-2003, 02:04 AM | #4 |
the only sensor i know of that has to do with oil would be the oil pressure switch..dont quote me on that either, haha, but you wouldnt be able to tap into that sensor, its just a switch (on/off) not something you could run a psi gauge on
back to subject, if you get the right adapter you should be able to remove the oil pressure switch and feed your sensor thru there. im not sure of the size but thats how my friend did his.
90 RPS1345 hybrid thingy & 01 IS300 |
11-02-2003, 02:04 PM | #5 |
u have to remove the stock oil pressure sensor thats located on the block. its below and to the left of the oil filter (passenger side of engine bay -looks the same as the one you got w/yours. btw, this is for electric oil pressure gauges)
the only thing is the stock oil light will no longer work.. but hey, if that light ever goes off.. its pretty much too late anyways right? besides.. thats why you have an aftermarket gauge for |
11-02-2003, 06:22 PM | #6 |
the pressure switch is 1/8" BSPT so if you use an autometer gauge you need an adapter from that to 1/8" NPT
i just pulled out my pressure switch and threaded in my sender and adapter
I never knew you could do that with an eggplant |
03-10-2004, 10:40 PM | #7 | |
i have an autometer electric oil pressure gauge and want to hook it up to my s13 sr. would autometer part number ATM-2269 be the correct part? it mentions in the description that it's for mechanical oil pressure gauges. anyone have any help for me on this? thanks.
zenki s14 |
03-11-2004, 10:37 PM | #9 |
I hooked up my electric Autometer gauge using the following adapter from Nissport. It is so straightforward with this adapter. You do not need to buy anything else if you are using an Autometer gage.
http://www.nissport.com/catalog/prod...Gauge+Adapters Glenn
91 Z32 TT, 92 Z32 TT, 90 240 LSX in progress, 09 GT-R, 18 Honda Ridgeline |
03-12-2004, 02:05 AM | #10 |
This thread has part numbers to a pretty extensive fittings site.
http://forums.freshalloy.com/ubbthre...e#Post67654121 |
04-01-2004, 07:46 PM | #11 |
sorry to bring up an old post but im baffled. I just bought an autometer sport comp electric oil pressure guage, well I went to install the new sender and it is way too big. It rubs right up against the oil filter. I know that it wont fit anyway as i need the adapter. but even if I had it. I cant install it with the oil filter. well I was looking at this nisport thing and it looks like I can install that and then have the new sender just one one of those other ports and it will be sideways, also i saw in the description that id doesnt say with use on sr20det, just de. but im guessing it will work. is it fine that it is sideways, doenst matter? thanks for the help.
I was going to, but I can not think of a sig less than 75 characters. |
04-01-2004, 10:42 PM | #12 |
The Nissport adapter works with an SR. I have the Nissport adapter on my SR20DET blacktop and am using an Autometer Sport Comp oil pressure gage exactly like you are trying to do. It fits with no issues.
Glenn
04-01-2004, 10:50 PM | #13 |
thanks, im gonna order it right now. you think I should get that radiator hose adapter too, for temp sensors or is there a better cheaper way to do it.
04-02-2004, 08:39 AM | #14 |
I think its really best to use some sort of hose, so you can clear the filter, and also isolate vibrations and keep stess of the aluminum threads.
SS hose would be best. I used a clutch hose from a Nissan Stanza. Kinda ghetto but thats how I roll, yos. |
04-04-2004, 12:12 AM | #15 |
I just used some fittings from the hardware store to make a sort of T. That way i could have the stock Oil press. sender and the autometer sender.
04-04-2004, 01:40 AM | #16 |
well I just ordered both those adapters, they are nice because you can add a few other things and a hundred bucks is nothing when you think of all the other money im going to have to spend.
04-04-2004, 01:26 PM | #17 | |
1992 240sx SE s13 silvia frontend conversion SR20DET, custom top mount turbo manifold, Precision SC61 turbo, blitz bov, HKS intercooler, Tial 38mm wastegate, tenzo-r shu-4's, ton of other shit. with clean new paint! |
