Old 10-06-2015, 04:50 PM   #1
Habibi240
Habibi240's Avatar
Habibi240 is an unknown quantity at this point
Misfire Sr20det
Searching and reading for a while !
Figured I'd make a thread
So my s13 sr has a random misfire at idle
Has a really bad cut out putting anything after 20% throttle
I don't know if my worn cam lobes have anything to do with it
<a href='http://i.imgur.com/HRp65Rh' title=''><img src='http://i.imgur.com/HRp65Rh.jpg' alt='' title='Hosted by imgur.com' /></a>
Timing marks are correct but when using a timing gun it was way off to get it at 15* the cas is at the end of the adjustment window ...
Things I've tested
Tried a freinds igniter
Unplugged each coil pack and injector
Tested cts and cleaned connection
Cleaned maf
Checked all clamps for possible boost leak (haven't done a test)
Mods
Walbro 400 (I know it's excessive)
Stock fuel lines
Z32 fuel filter (1hour of run time on it)
Stock 370inj
Wiseco 9.0 comp Pistons 87mm
Apexi 1.5 - 87
Stock valve tran fresh seals
T28 s15 bb
Fmic
It was doing the idle bog/misfire before I had a piston meltdown but only popped every now n then under load .
I'm gonna do a boost leak soon but in the mean time can I get some ideas tossed up..
Let me know if you need any more info.
Thanks
Also I don't know afr #s yet . Wideband on the way
Habibi240 is offline   Reply With Quote
Old 10-06-2015, 05:11 PM   #2
cbeuglas
cbeuglas is an unknown quantity at this point
Here are a few ideas. Clogged fuel injectors. Test fuel pressure. TPS has to be unplugged when checking timing, also I could not get an accurate reading off the timing loop. I had to use a plug wire (ka24) between the number one coil and number one spark plug to get an accurate timing reading.
Sent from my SAMSUNG-SM-G920A using Tapatalk
cbeuglas is offline   Reply With Quote
Old 10-06-2015, 05:13 PM   #3
cbeuglas
Also what is the vac. at idle as it could be very well be a boost leak.
Old 10-06-2015, 05:26 PM   #4
Habibi240
Habibi240's Avatar
I have a cheap ass boost gauge that only reads boost and I did the spark plug wire loop trick
Old 10-06-2015, 05:35 PM   #5
Habibi240
Habibi240's Avatar
Oh and plugs gapped at 32
Old 10-06-2015, 06:02 PM   #6
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
Have you tried another CAS?
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 10-06-2015, 06:29 PM   #7
Habibi240
Habibi240's Avatar
No actually I haven't I could test mine right ? Imma search that now
Old 10-06-2015, 07:25 PM   #8
blksylv
blksylv's Avatar
Trader Rating: (33)
I'm not too sure. I had an issue with an misfire at idle, replaced a bunch of things and it ended up being the cas. My misfire would get worse the longer I drove it. It would bog a little under boost though.
Old 10-12-2015, 03:10 PM   #9
Sills
Sills's Avatar
Sills is an unknown quantity at this point
My Rb had a nasty misfiring issue, especially in the higher rpm range.
I tossed in some fresh Ngk V-power BRK7E(s?) plugs and gapped them to 0.22.
Running perfectly now, way better than the old NGK iridiums that were in it.
Only costed me about 25$ for 6 plugs. Not sure what ones to use in an Sr as mine blew up long before I got to change the plugs in it.
Sills is offline   Reply With Quote
Old 10-12-2015, 03:53 PM   #10
Habibi240
Habibi240's Avatar
It was my ignitor chip I forgot to update you guys
