10-22-2014, 10:45 PM | #1 |
S13 convertible vh
not for sale any more. I'm going to part It out so if any one is intrested
located in Chula Vista phone (619) 867-7016 Asking $5000 -New battery still unopened -vh45 1995 -Z32 trans 5 speed n/a -Made the Hood clears with out cutting a big ass hole on hood like every other vhvg swap. -Xcessive full vhvg swap kit -Vh45 s2 harness conversion -Power steering cooler, Billet SS reservoir pc black, B&M cooler, an lines, assembled by fragola. -Tomei piston oil cap -Greddy drain plug -Redline power steering fluid -Redline transmission fluid -Redline 12oz rad coolant -Act 6 puck -Fidanza flywheel -Mizu radiator -Isis Fan shroud -Modified stock Headers -Exhaust 2.5 Y to a dual 3" -k&n cone filter -Z32 short shifter -Fresh oil change -New Spark plugs -New z32 gas filter -New water hose for rad and heater -Jack Daniels coolant reservoir -Walbro fuel pump -Heat tape wrap on fuel lines -Earl's perfomace Flame Guard hose on clutch line & power steering line -Two 12" electric fans with toggle switch -fuze -dif fan controller -New Pbm water neck temp adapter -Zilvia frontend -Origen 20mm & 30mm over fender -Wheel tubs -Trunk holes welded -removable rad support -engine bay stitch weld -5 speed converted -Z32 Master Cy. 1" w/fitting -DIF SS brake lines conversion -Front z32 brakes & rotors -Rear z32 brakes, rotors dust shield -5mm spacer front & back -5 lug Front ichiba -5 lug Rear z32 hub -10.5 x17 all mustang reps with nexen tires -Front & rear whiteline swaybars adjustable 3 levels -pbm coilovers less then 1000 miles -Weldeddiff by pbm -Pbm sub solid risers -Pbm rucas -Pbm toe rods -Godspeed rear lower support bar -Hids -Nrg steering wheel -Nrg short hub -Nrg quick release -Flock dash board no cracks -Driver Momo bucket seats with rail -battery relocated to the back -240sx stock lip -rockford fosgate power speakers
INSTAGRAM @ari_flz my 1978 Fairlday Z & s13 vh build Last edited by Steo; 11-13-2014 at 05:49 PM.. Reason: Not going to sell completely any more. |
