01-06-2017, 10:56 AM | #1 |
PBM coilover problem
Alright, so I bought brand new pbm Comp coilovers.. backs are fine, but the fronts, I have no clue what happen. So my front right wheel has 0 camber without changing the camber adjustment on the coilover, but the front left has hella camber and its rubbing on the tire a little. When I take my bumper off and look at the coils from the front one is at an angle and one is almost straight up and down. What is causing this? Can I adjust the knuckle somehow? I noticed the knuckles are at different angles also..
01-06-2017, 03:36 PM | #2 |
Something is possibly bent. FLCA maybe?
http://www.nissanroadracing.com/ |
01-06-2017, 03:49 PM | #3 |
That's what I thought, but everything looks unbent. The stock struts I had I never had any alignment problems.. I dmd pbm and they said to jack up my car and do something with the knuckle so Ima check it out after work
01-06-2017, 03:57 PM | #4 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
PBM coilovers have offset spindle mounts. Make sure both of your spindle mounts are flipped the right way. They're probably like this right now / / instead of like this / \
01-06-2017, 04:11 PM | #5 |
Good thing you said that because I had no idea, I'll check when I get home. I was asking my friend about it and I brought that up and he was like "nah they don't have that" lmfao. Thanks, I'll let you know if that was the problem
01-06-2017, 10:08 PM | #7 |
You guys will never believe what it was haha, my friend flipped the front lower mount on one when I first got them.. so this entire time I'm trying to figure this out for no reason lmfao
