Old 07-19-2008, 12:03 PM   #1
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
Car wont crank!
Last week i had an injector to go out. So i pulled the fuse under the hood for the fuel pump. cranked the car and let it run untill the car died. I then removed the injector and bought one from advance. i put it in the day after. Now when i go to crank the car it wont crank. it turns over but thats it. When the key is turned to the on position i hear the fuel pump prime but the car still dosent crank. anyone ever had this problem or know what the problem is? thanks for the help.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 07-19-2008, 12:36 PM   #2
tha240star
tha240star is making a name for him/her selftha240star is making a name for him/her self
when u say it doesnt crank, do u mean it wont even turnover?
tha240star is offline   Reply With Quote
Old 07-19-2008, 12:44 PM   #3
BoostedCoupe
it turns over but wont fire.
Old 07-19-2008, 01:02 PM   #4
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
specify what motor you have please? need more info
S-Nation S13 is offline   Reply With Quote
Old 07-19-2008, 01:16 PM   #5
BoostedCoupe
ka, with just little bolt ons. header, intake, and a msd ignition setup.
Old 07-19-2008, 03:03 PM   #6
BoostedCoupe
Woot woot new update. I was smart today and had a wise idea to unplug the maf and all injectors and try to crank it. It cranked and ran for a couple seconds. Then i noticed fuel coming from my intake. So i took the intake tube off and there is about a half quart of fuel there. So i got all of the gas out and still not cranking.
Old 07-19-2008, 08:56 PM   #7
S-Nation S13
Trader Rating: (92)
ok sounds stupid plug everything back up and then check the 5th spark plug im assuming its a ka24de from s13? if so look at that plug from the igniton coil or your msd coil friend had it happen to him found out that plug wanst pushed i all tha way try that pm me if you still need help
Old 07-20-2008, 12:24 PM   #8
BoostedCoupe
that wire works. it would crank and run befor i did the injector change. now it seems like its flooded to hell. can i remove the spark plugs and hope that the fuel will evap out of the motor.
Old 07-20-2008, 02:08 PM   #9
Clowny
Clowny's Avatar
Clowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to behold
Send a message via AIM to Clowny Send a message via Yahoo to Clowny
try taking the spark plugs out and turning the motor over for a bit. if there is fuel in the cylinders, itll shoot it all out. have some towels handy to clean up the mess though.
Clowny is offline   Reply With Quote
