07-18-2008, 09:19 PM | #1 |
S13 Q45 front brake conversion question
Hey, I just picked up a pair of Q45 front calipers for my s13, and I was reading over some posts about the conversion. Someone mentioned that you may be able to use Altima rotors with Q45 calipers so you dont have to drill anything for 4 lug. Has anyone used these before, and are they any different performance wise from the Q45 rotors?
Also, can anyone reccomend any budget performance pads for the Q45's? Thanks -Llama
If you think my hatch is fast, you should see my gixxer! |
07-18-2008, 09:59 PM | #4 |
yes, use it as a template, and stick a 1/2 inch bolt in the hole that lines up and drill the other holes. be sure to keep everything lined up.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
07-19-2008, 12:54 AM | #5 |
take it to a brake shop and they will drill it for you! otherwise save and go 5 lug like you should. i had this swap in my s13. great brakes but wait to go 5 lug! if you have more questions pm me!
TEAM SUS*PECT |
07-19-2008, 02:08 AM | #6 |
hey im havin the same issue tooo... i have my broken down Q45 sitting on front of my house. so i have plenty of parts to swap on =]....vlsd. fuel pump, throttle body and MAF sensor = ] go big or go home.. lolx
well hey.. is the rear calipers any different maybe bigger from the Q45 or no?... this thread really help. =] Last edited by DDDsquad_s13panda; 07-19-2008 at 02:11 AM.. Reason: add some more question. |
07-19-2008, 09:54 AM | #7 | ||
07-19-2008, 10:11 PM | #8 |
im debating if i should jst take my Q45 front brakes and put it in my s13. but im also wondering id the rear breaks of the Q45 any bigger than the stock S13 brakes because i dont really see alot of people talking about swapping rear Q45 calipers to S13.
