Old 07-18-2008, 11:05 AM   #1
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
turbo oil return gasket part number?
hey guys.. I need a new gasket for the turbo oil return. Anyone have a part number or where I can get one in the North East?
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 07-18-2008, 11:26 AM   #2
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
I cut one out of that rubber/cork gasket material you can find at parts stores, and haven't had any leaks or problems. Other people might say it's a bad idea, it's worked for me though.
Or you could buy one from www.atpturbo.com
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 07-18-2008, 03:42 PM   #3
DJ_Sunrise
true.. i just might do it, atleast as a temp kind of deal. Any idea if the oil return gasket on the T25 and T28 are the same??
-Bart
Old 07-18-2008, 03:46 PM   #4
1QUICK4
Stop or I'll Shoost
1QUICK4's Avatar
1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection
Send a message via AIM to 1QUICK4 Send a message via MSN to 1QUICK4
-Bart
I think the S15 T-28 is the only one that is different
-383 RWHP & 407 RWTQ-
Review Thread= http://www.zilvia.net/f/showthread.php?t=201106
1QUICK4 is offline   Reply With Quote
Old 07-18-2008, 03:49 PM   #5
burnsauto
burnsauto's Avatar
The Z32 twin turbo should have the same gasket, local dealer should be able to pick them up.
Old 07-18-2008, 04:01 PM   #6
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
message length
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
