04-06-2007, 01:16 PM | #1 |
S13 BC Racing BR Coilover Review
I have owned my 1990 240sx for a little over 2 years. I recently upgraded from a RSR Spring and Tokico Shock set-up to the new BC Racing line of coilovers. The new BR Series comes with 8/6 spring rates and are 30way adjustable. When I first opened the box they felt just as heavy as the flex’s that a friend and I were installing that same day. The BR’s have pillow ball mounts at all four corners and a tapered cup design, which prevents unwanted height and preload adjustments while driving.
The rides firm yet very smooth even with 8/6 spring rates this shows how controlled the dampening is and how well BC did on building there new line of coilovers. The install took about 2 hours including adjustments of the ride height and camber. The BR’s can be adjusted to go pretty low, I tucked my 18’s in the rear and still had about 2 inches to go lower. For the test drive I went up PCH from Newport Beach to Malibu, dividing miles between the different settings. What really sold me on these was how smooth the ride is. At full stiff the car was stiff as a board and extremely steady. At the softest setting the ride was very comfortable and smooth with no bouncing. Hands down the BR series coilovers are excellent, I highly recommend them to anyone who wants a great product by a company that produces high quality parts with a great price. The only suggestion I have for BC is to offer a 9/7 spring rate for the BR’s, Here are sum pics of them installed |
04-06-2007, 02:49 PM | #3 |
I've never heard of these. who sells them?
Petition Nissan to Make the IDx on http://IDxClub.co ! |
04-06-2007, 02:58 PM | #5 |
you tucked actuall wheel??
or the tire?? looks like you can drop alot more, put them all the way down, and lets see the car on the 18's
giantroboteyes.wordpress.com/ |
04-06-2007, 03:09 PM | #6 | |
no i tucked the actual wheel. that pic is after the alignment i'm not going any lower tell i get my rear arms |
04-07-2007, 01:01 AM | #7 | |
Even though you can technically drop they collars down all the way down the shock body, it isn't recommended. 1) its a lot more noisy when there is no preload on the spring 2) you are minimizing shock travel, a real nice way to ruin your coilovers a lot faster. The real lowness test lies up front. are you maxxed out up front? |
04-06-2007, 03:02 PM | #8 |
ECHO
http://www.zilvia.net/f/showthread.php?t=115562 240, the ride's nice i dd it on 13 clicks and the ride's very smooth nismo, thats one thing i did not do before he left back to mexico i'll get more pics of me car up this weekend when i wash it |
04-07-2007, 01:03 PM | #10 |
hahah wtf are you talking about??? that is the point of coilobers, to still maintain travel while going lower.
04-07-2007, 02:40 PM | #11 | ||
Look at this picture... Quote:
04-07-2007, 05:06 PM | #12 | |
04-07-2007, 05:50 PM | #14 | |
No, because if you bottom out the lower mount, you have to drop the spring down
Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
04-07-2007, 06:00 PM | #15 |
look at the front coilover first.
the diff is the front spring is sagged a bit and the rear is not when the car is up on jacks. looks like it can be dropped more on the rear without sagging. looks great btw. |
04-07-2007, 08:30 PM | #19 |
The link for the group buy has already been posted for whoever keeps asking ^^ http://www.zilvia.net/f/showthread.php?t=115562
04-08-2007, 04:21 PM | #21 | |
1qwk240
Did you graduate highschool? It seems like you didn't because you have a pretty incredible skill for writing run on sentences.
04-08-2007, 05:30 PM | #22 | |
04-08-2007, 05:41 PM | #23 |
Mainevent212- jk
I just want to clarify if this system is able to offer a good drop. One without going to the extent of drooping springs. I agree with one of the above posters. Drooping springs will kill your shock absorbers. Plus, what are the chances of landing between spring seats correctly always? I'm sure thats not safe. |
04-08-2007, 07:44 PM | #24 | |
Drooping springs isn't the end of the world. If you droop them like 10 feet you will have problems, but 1" isn't going to kill anything.
These are made by the same factory as megan racing shit IIRC. I'm pretty sure I didn't need to use a comma there, by the way.
04-08-2007, 08:23 PM | #25 |
I have done a bit a searching around. The rumors are they are made in the same factory as megans, but so is apexi. I don't believe that really matters, as every brand probably has different specs. These must for sure, as they are bigger than megans (piston rod). Either way, they seem to be a promising kit. Read this review I ran into http://features.evolutionm.net/article.php?id=84
04-10-2007, 11:02 AM | #26 |
Sorry for the late replys guy's
in the pic that DriftSpecial180 posted i had just put them in and did not adjust the ride yet and no i did not drop spring and yes bc racing makes the magens aswell as alot of others out there in japan i also need to change my front tire size so i can lower |
04-10-2007, 02:43 PM | #27 |
Trader Rating: (18)
Feedback Score: 18 reviews
And these just like other modern coilovers do not loose suspension travel when you lower them. They are adjustable length coilovers. Drooping spring would only take away from the height adjustment side and wouldnt do anything. You could droop the spring to lower it but then when you wanted to go super low you would loose that adjustment because the bottom spring perch would hit the lower shock mount faster. Looks like many other coilovers that have plenty of adjustment in the rear. Toe rods usually hit before coilover is even close to bottom on rear. Front is where most people cant go any lower but like Michelle said most cars are limited by tire size anyway.
04-10-2007, 03:17 PM | #28 | |
04-10-2007, 10:00 PM | #30 | |
Trader Rating: (18)
Im not there. Take out the yet because I will never be "there" I like my car to handle correctly. |
