Old 08-29-2014, 02:00 PM   #1
So Make Like
So Make Like's Avatar
So Make Like is an unknown quantity at this point
SR20DET question!
I just finished my rebuild and ran into an oil leak on the exhaust side of the motor. Unless only one spot of my upper pan gasket is leaking, I'm sure it's the oil feed banjo bolt that's leaking. Looking at it now, how many copper washers should be on there? Mines only has one on the outside.
[BLOCK] (BANJO) | ===[]
^ That's how it sits now. Am I missing one on the inside? I hate these things.
So Make Like is offline   Reply With Quote
Old 08-29-2014, 02:16 PM   #2
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
It should be banjo bolt -copper washer-turbo line-copper washer-block
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 08-29-2014, 02:18 PM   #3
Kaifd3s
Kaifd3s's Avatar
Kaifd3s is on the path to ruinKaifd3s is on the path to ruin
If your going to fix the leak, might as well put some -AN fitting on there and forget about leaks.
Kaifd3s is offline   Reply With Quote
Old 08-30-2014, 11:49 PM   #4
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
The stock banjo bolt is actually 100% the best possible fitting to have in that area on an SR20. I have seen too many cases of -AN fittings strip that area because the threads are not machined exactly the same.
I can however agree that a banjo bolt using -AN set of lines would be good. Such as the DIF Forged.
Agree that it should be Banjo Bolt > Copper Washer >> Turbo Line >> Washer >> Block
om3ga is offline   Reply With Quote
Old 09-01-2014, 09:55 PM   #5
So Make Like
thanks guys, i have a ss braided line with the banjo bolt end for the block and a 90 degree elbow for the turbo side. i got an extra copper washer from oreilly's and it stopped leaking. thanks for the input!
Old 09-02-2014, 01:09 AM   #6
LoganDavenport
LoganDavenport's Avatar
LoganDavenport is an unknown quantity at this point
Yep this is correct
LoganDavenport is offline   Reply With Quote
