Old 03-20-2017, 01:24 AM   #1
240msh
240msh's Avatar
240msh is an unknown quantity at this point
SR20DET Swap Help
Alright so I just bought a blacktop sr out of a 180sx clip. Im swapping it into my s14, and im pretty sure I can do all the wiring myself, if not ill buy a ws harness. Anyway, im going to be buying the isr m spec fmic kit, and ive read a couple forms saying how you dont need a bov if your running stock boost? Im lost haha.
240msh is offline   Reply With Quote
Old 03-20-2017, 01:32 AM   #2
240msh
240msh's Avatar
Actually I have one more question, so since im making my own heater hoses, what do I do with the oem s14 temp sensor on the oem hoses?
Old 03-20-2017, 05:44 PM   #3
Nissan2nr22
Nissan2nr22's Avatar
Trader Rating: (28)
Nissan2nr22 is an unknown quantity at this point
Feedback Score: 28 reviews
Of course you don't need a BOV. Most people actually dont run BOVs. Whoever runs BOVs is usually for the sounds.
The OEM S14 temp sensor is on the engine not hose. You leave that plugged in.
Nissan2nr22 is offline   Reply With Quote
Old 03-20-2017, 09:51 PM   #4
240msh
240msh's Avatar
Yeah I searched it up for awhile and found that I really dont need a bov unless im running alot of boost. So i got that figured out. And thats exactly what I thought, now im just confused on what the hell that cable is going through the firewall to the oem heater hose? What is that?
Old 03-21-2017, 12:49 PM   #5
Benslidin180
Benslidin180 is an unknown quantity at this point
BOV is to prevent compressor surge. Basically what happened is when u shift or start to go from boost to vaccum. The air goes back and stops the turbine from spinning that the flutter you hear. This causes your turbo to go out faster. Yes with more boost the worse this is. I don't run BOV just becuase I like the compressor sound and don't like all the sounds. There are turbos these days made to reduce surge but not 100%
Benslidin180 is offline   Reply With Quote
Old 03-21-2017, 01:44 PM   #6
jedi03
jedi03 is an unknown quantity at this point
got pics of your cable? it may be an actuator arm for the heat shut off
Old 03-22-2017, 01:36 PM   #7
240msh
240msh's Avatar
https://gyazo.com/f44eb89676ba05ec2beb8531bea34813 thats what it looks like, also can anyone tell what sr ecu this is? its off of a blacktop but the stick doesnt look like it says e5/e6 https://gyazo.com/7d757ae55e11186a4f52508d68b8cf6c
