Old 03-21-2017, 10:07 PM   #1
SidewaysS13ka
SidewaysS13ka's Avatar
SidewaysS13ka is an unknown quantity at this point
s13 1992 s13 hatch (5spd, southern car)
Rob Fisher
18219
5704015838
Cash, no trades, must pick up
Title in hand
2,000 obo
The car is/has been on jackstands for the past year, so in order for me to get it mobile I have to attach the front struts, outer tie rods, knuckles and LCAs. Front LCAs will need ball joints.
I don't have many pictures of the car, just of the way it's been sitting for the past year and I haven't really made any progress since then.
240 parts list:
*CAR IS A ROLLING SHELL*
Asking 2,000 obo
180sx hood (driver side corner is bent at top of hood)
180sx center garnish
Duraflex 50mm rear overfenders (fit like ass IMO)
Rear bumper cut for rear diffuser
Unfinished wire tuck (needs lower trans harness wires extended and battery cables ran)
Gk-tech offset tie rod spacer
Gk-tech "power brace"
Pbm eccentric rack bushing
Solid steering bushing
All ISR arms
Spl solid rear subframe bushings
J30 lsd rear with j30 axles
Gk-tech handbrake extenders
Goodridge braided brakes lines all around
ISR braided clutch line (not installed)
ISR tie rod package (outer tie rods not installed)
Modded front knuckles
Front LCAs boxed and extended 25mm with villains extension plates
S14 non abs brake booster
Z32 master (the 1 1/16 master)
Drilled and slotted rotors all around
Brand new front sway bar end links
Front wheel wells removed
Front pinch welds and "tire killers" removed
Two sharknose bumpers
Extra rear hatch (needs more metal work, third brake light is shaved)
Brand new windshield
Manual windows
All hvac and ducting removed under dash
All fender hardware replaced with gold m10 bolts
Interior is in good shape, no major cracks in dash, just one pellet sized ding on the passenger side of dash.
Thank you for looking. ��
Leaks,Creeks,Squeaks, and other random problems. Yup you own a 240.
SidewaysS13ka is offline   Reply With Quote
Old 03-23-2017, 03:54 AM   #2
SidewaysS13ka
Mods you can lock this.
