02-06-2016, 05:49 PM | #1 |
Okada Projects SR20 Coilpacks Issue
I got the new coil packs in a few weeks ago and installed them and then car wouldn't start. Thought it was the harness because I heard a crack and it was previously damaged, so I bought a new coil pack sub-harness from wiring specialties and that wasn't the issue. Swapped my old coils in because I realized it might be the coil packs and not a broken harness and the old ones fire it right back up.
Can't figure out if these coil packs are defective, or I'm lacking some part. It says plug and play, so I'm not sure. But pretty much 100% of the directions are Japanese anyway. New coil packs didn't make spark at all, but were getting warm like they were turning on. My question is -- has anybody used these and did you need to do anything additional to make them work? I've emailed Okada but that was 2 weeks ago with no response yet. Searched before I asked, just couldn't find any good info. |
02-08-2016, 07:35 PM | #3 |
I think you are right. These are s15 coils and I have an s14 sr20. I've done some research but I'm not 100% clear. From what I've read i should remove the stock ignitor and run an s15 coilpack harness, correct? Or am I missing something?
02-08-2016, 08:13 PM | #4 | |
Found it. I'll share it here incase anybody has anything to add. I would not recommend purchasing these from Nengun if you are looking into a set. They've been nothing but rude about all questions asked, doing nothing but deflecting everything I've asked or said without actually helping at all.
