Old 03-25-2018, 04:30 PM   #1
silvia910
silvia910 is an unknown quantity at this point
What intake pipe to use with gt2871/z32 maf?
Getting everything ready to drop a gr2871 and z32 maf into my sr. What intake pipe does everyone use? I’d prefer to use something that doesn’t cost as much as a ridiculously price apexi power intake. Does the apexi even have the port for the PCV hose? I was going to go with the pbm intake pipe but it didn’t have the port for the crankcase vent hose either.
Preferably something I can purchase to drop in vs getting one fabricated/welded. Any suggestions or pictures of your own setup?
silvia910 is offline   Reply With Quote
Old 03-25-2018, 08:32 PM   #2
Kingtal0n
Kingtal0n's Avatar
Kingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really nice
greddy piece is standard but I always make one to set my car apart from everyone else. Be sure to include PCV hose port on it if you want it to be taken seriously.
Old 03-26-2018, 05:38 AM   #3
JM216S14
JM216S14's Avatar
JM216S14 is on a distinguished road
I used a OEM Inlet with a rubber 2.5" to 3" 45 and a short piece of 6" to the Maf
JM216S14 is offline   Reply With Quote
Old 03-26-2018, 05:52 AM   #4
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
I made my own out of a 3 inch diameter stainless steel tube and bought a good quality 45 degree coupler
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 03-26-2018, 08:20 AM   #5
jedi03
dunno price on HKS but its pretty good...I prefer the apexi compared to all the rest...a bit pricey yes but worth not having a headache!
Old 03-26-2018, 08:31 AM   #6
s13silvia123
HKS I believe is discontinue. I know for sure the Hotpipe with BOV is discontinued.
Old 03-26-2018, 11:28 AM   #7
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Spend $20 and make your own.
[email protected]
hanzbrady is offline   Reply With Quote
Old 03-27-2018, 04:34 PM   #8
LoSt180
LoSt180's Avatar
LoSt180 is an unknown quantity at this point
I have the Apexi "induction kit" for S14/15. It has the inlets for both the recirc tube and wastegate solenoid. The PVC hose connects to the elbow on the turbo inlet. It also tapers down to the stock turbo inlet pipe diameter.
So if your 2871 has the SR housing, it'll work. If it's the version with a 3" opening, then look at a different option.
LoSt180 is online now   Reply With Quote
Old 03-28-2018, 02:49 PM   #9
yes im a newb with a 240
yes im a newb with a 240 has a little shameless behavior in the past
That looks really nice, but do you have your ps pump removed or relocated somehow? Or am I just blind
Sent from my SM-G955U using Tapatalk
yes im a newb with a 240 is offline   Reply With Quote
Old 03-28-2018, 07:30 PM   #10
hanzbrady
hanzbrady's Avatar
My car didn't have power steering so I suppose my intake was simpler than most to make.
[email protected]
Old 04-09-2018, 07:41 PM   #11
silvia910
Any other pictures or suggestions? Still trying to find a good option with the pcv vent hose.
Old 04-09-2018, 08:45 PM   #12
Blk96t
Blk96t is an unknown quantity at this point
Easiest and best fitting is to use the s14 or s15 sr inlet. It has the valve cover vent tube built in.
Then 45 deg coupler that goes from the turbo inlet size 2.25 (I think)to 3". Then abou 6-8" straight 3" pipe to your z32 mafs.
Look at the pbm website for pics of their intake.
There are a few different ways to do it.....
Blk96t is offline   Reply With Quote
Old 04-09-2018, 08:48 PM   #13
Blk96t
Which version 2871r do you have?
Like the pic above?
I've always bought the s14/s15 replacement style. It's physically the same on the outside as the t28
Old 04-16-2018, 11:19 PM   #14
Driftaholic84
Driftaholic84 is an unknown quantity at this point
I have been dealing with this issue... good luck with finding a proper setup. I don’t know if you’re planning on recirculating or if you are running a catch can, but if you want a bolt on option you are really down to 3/4 options depending on how you want to look at it..
GReddy Kits:
-S13sr part number 11920200 this kit is for use w/ s14/15 turbo (you can use this with gt2871r) and z32 maf. This kit has turbo inlets that allow you to bolt on s13 ic piping!!
-s14sr part number 11920201 this kit is for sue if you have a s14/s15 sr. It is the same as the kit above, but with no turbo inlet pipes.
APEXi suction tube, is like $80 more and you still have to buy a maf adapter, because it’s for s14sr w/ map sensor so there’s another $50
I bought the last greddy s13 suction kit available in the county last week. The y are on backorder for both s13 and s14/15 for 2 months and I believe the apex suction tune is on backorder for another few weeks. You can however get the pbm intake pipe kit that allows you to run a elbow fitting to a 3” straight pipe (with no recirculating or vacuum port) for $70 but you would have to still buy a maf adapter and filter. You would also have to have ports welded in place if you wanted those features out of your intake. Isr also makes a kit for like a buck ninety that has no provision for bov or vac port but has maf adapter and filter. Hope this helps.
Driftaholic84 is offline   Reply With Quote
Old 04-16-2018, 11:21 PM   #15
Driftaholic84
You’ll have to modify your inlets to run s13 hotpipe if I’m correct unless you get the greddy s13 kit as well, because they come modified for you. It’s the only true bolt on solution for our setup I believe.
Old 04-16-2018, 11:51 PM   #16
silvia910
From everywhere I’ve looked, I am sitting in about the same exact body as what you’ve come up with Driftaholic... fortunately, the gt2871 I bought came with the Greddy outlet, so I’m good on using my t25 sr hotpipe, without having to deal with repositioning.
All I need now is the proper oil drain tube and an intake pipe solution.. I have the .64 version and I also think I have the turbo inlet pipe with the t25 positioning as well.
Old 04-17-2018, 12:23 AM   #17
derass
Neither the S13 or S14 compressor inlet pipe on a GT28R compressor housing (what your GT2871R has) will line up with a stock-style S13 intake. You can either cut, re-clock and weld, or buy clocking plates.
I chose the latter. The DIF ones from FRSport are quite nice with o-rings.
Old 04-17-2018, 07:11 AM   #18
Driftaholic84
For the oil drain, I ordered an Isr unit. The drain tube is part #IS-T28Drain. I then have a OEM S15 rubber hose part #: 15198-69F00 connected to that, going to the fitting on the block. Granted, this is all sitting in my living room at the time being, but fitting/installation is happening today, weather permitting.
Old 04-17-2018, 07:14 AM   #19
Driftaholic84
Btw, it you do already have the GReddy inlets for your turbo, (you will know because they say GReddy on them) or you have modified oem units, I ran into a guy on Facebook selling the greddy tube for like $60/70 shipped. It’s a little beat up and doesn’t come with filter or maf adapter, but you can still purchase both of those parts new from GReddy and still have an intake without waiting til mid June.
Old 04-17-2018, 09:44 AM   #20
silvia910
This is what I’m working with.
https://ibb.co/mSMm7S
https://ibb.co/kf6a1n
https://ibb.co/c0DzSS
https://ibb.co/eEntnS
If that Greddy intake works, I’ll def take it. Thanks buddy, just lmk the info.
Old 04-17-2018, 12:13 PM   #21
S-Verteen
S-Verteen is an unknown quantity at this point
https://store.partsshopmax.com/shop/silvia/Engine/
S-Verteen is offline   Reply With Quote
Old 04-17-2018, 02:17 PM   #22
Driftaholic84
It looks like you have a greddy inlet and a modified inlet so that should work. Let me see if dude still has it.
Old 04-19-2018, 10:34 AM   #23
Driftaholic84
I couldn’t find buddy with the greddy tube for sale. I did get mine in yesterday though and it is really nice. Everything is cast aluminum. The inlet pipe and the intake tube are polished and the intake inlet is left rough cast. Comes with everything needed including a new maf pigtail. Definitely recommend this kit if you can find it.
