12-14-2013, 01:46 PM | #1 |
S13 1uz swap
Hey guys need a little help from the people that have done this...
I have a 91 s13 got a 91 ls400 1uz wanted to know if I could use my ka radiator for it since it's an aluminum aftermarket one. Also what would I use for the hoses and for the power steering lines? Just want to get the best stuff so that the swap will be swift and simple. I have everything els! ImageUploadedByTapatalk1387053896.241901.jpgImageUploadedByTapatalk1387053909.719927.jpgImageUploadedByTapatalk1387053922.354043.jpgImageUploadedByTapatalk1387053936.540185.jpgImageUploadedByTapatalk1387053945.056209.jpgImageUploadedByTapatalk1387053952.440162.jpg Thanks! And if you did this swap and don't mind helping out in the Bay Area let me kno! Or pm me your number! Thanks guys! Sent from my iPhone using Tapatalk |
12-15-2013, 12:20 PM | #3 |
it doesnt matter what radiator you use. you will just need custom hoses. an sr radiator would be better though, since the top hose would come off the right side. i hope you have a custom driveshaft as well
12-23-2013, 02:54 AM | #10 |
Is that from Brett Collins? I am going 1uz once my clutch or my engine decides to die. Cheapest and easiest swap from what I have heard.
Here are some builds I have bookmarked for when I start the build: V8 Silvia Build | DriftWest 1UZ S13 Coupe Build - Nissan 240SX Forums |
12-28-2013, 04:27 PM | #11 | |
and yes it is! |
10-19-2014, 02:18 PM | #14 |
hey sorry its been a long time but i did manage to get the swap parts from a buddy of mines and get it all together and put in now all i need is wiring. ive been so busy thats why i havent started it but i do have weekends off now so hopefully i can get it moving before it gets super cold out.
10-19-2014, 11:01 PM | #15 |
transmission moves back to give clearance to the fan and radiator on the car. if you dont move the trans back you'll run into fitment issues with your radiator and pulleys on the car. those engine mounts where ment to be adjustable. i shoved the motor as far back as possible for weight distribution reasons.
make sure to get the right flywheel and clutch parts and follow all the instructions from Brett. including the knife edging the starter, and replace your spark plugs and injectors before you drop it in. I did acomplete rebuild on my 1uz before i swapped it in because i intend on some mild cams and 8.5k rpm redline.
Mad Moody Science LLC In house is the best way. |
11-23-2014, 02:41 PM | #16 |
Sorry to revive an older thread, but I can't find anything when it comes to the wiring of this swap.
I am fairly inclined when it comes to wiring, I've wired in all my swaps, but I can't find next to anything about this one. My question is, for those of you who have completed this how detailed is the wiring conversion? I'm not exactly asking for a complete run down of every wire, but if you know of a good thread or pinout diagram that would help I would greatly appreciate it.
'92 240sx w/'93 SR Blacktop /// '94 RX7 FD3S /// '11 370z RIP |
