03-31-2015, 08:54 PM | #1 |
Witch seat rails are lower?
I search cant find the andswer i have pair of recaro sr3 bottom mount seats and want to put it in my s14 witch sliding rails are the lowest? Is bride low max lower then bride type-mo? Or any orher rail thanx
03-31-2015, 10:11 PM | #2 |
You need type MO most likely as you have a bottom mount seat
MRP Manufacturing |
04-01-2015, 08:00 AM | #5 |
You really need side mounts seats in an S chassis. you can barely get the OEM height when mounting side mounts the lowest possible, and any bottom mount will be higher than that.
Maybe not a problem to japanese people, but western ppl are not that small. The cheapest safe side mounts i found were the buddyclub ones (locks on each side, enough material thickness to hold the seat). Yet i needed snug fit sparco corsas (and a bit of hammer on the trans tunnel near the mount) to mount them low. |
04-01-2015, 10:32 AM | #9 |
Sparco bottom mount on Bride MO rail. Sits as low as my spec r seat. Higher in the front by a little due to seat design
MRP Manufacturing |
04-01-2015, 10:44 AM | #10 |
If you have a sidemount seat stay away from buddy club rails. Lowest setting is higher than stock seat. It sucks.
http://www.nissanroadracing.com/ |
04-13-2015, 04:30 AM | #14 |
Trader Rating: (29)
Feedback Score: 29 reviews
Could have the bride rails customized. Cut the c-channel out from the driver's front floor, hammer, cut and weld in new L metal where it splits, cut and weld on the rails, can damn near have the seat on the floor. Miles of headroom after.
04-17-2015, 01:26 PM | #17 |
04-17-2015, 09:16 PM | #18 |
I'm running the planted rail in my car.
20150108_135130_zps6siyxiya by Andwele Hall, on Flickr20150108_135230_RichtoneHDR_zps8gnoynf1 by Andwele Hall, on Flickr
95 240sx RB20 415whp 91 Nx2000 VVL yo Last edited by Yellow4g63; 08-20-2017 at 08:41 PM.. |
04-17-2015, 11:33 PM | #19 | |
MRP Manufacturing |
04-19-2015, 02:13 PM | #20 | |
Trader Rating: (29)
