Old 02-25-2012, 01:34 PM   #1
patsajak
patsajak is an unknown quantity at this point
hatch strut thread missing?
so i was changing my hatch struts today and the female threading inside the hatch fell out and back inside the hatch down the hole where the threading should be. I heard it roll down and tried to roll it back and catch it with something but them it dissapeared. How did this happen and how do i fix it
patsajak is offline   Reply With Quote
Old 02-25-2012, 01:55 PM   #2
RandallSharp
RandallSharp's Avatar
RandallSharp is an unknown quantity at this point
I'm not sure I fully understand, but maybe you could try using a powerful magnet to bring it back up?
1991 240sx Hatch Daily'd!
RandallSharp is offline   Reply With Quote
Old 02-25-2012, 02:04 PM   #3
patsajak
i know i dont even understand, its just an open hole, there is no where for te strut to thread in
Old 02-25-2012, 02:10 PM   #4
RandallSharp
Back off a little and retake the photo. I need to see the location better and I'll go check mine out.
Old 02-25-2012, 02:42 PM   #5
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
the nut inside of the hatch came undone. you are gonna have to have a welder weld a new nut inside the hole.
rcdad123 is offline   Reply With Quote
Old 02-25-2012, 03:27 PM   #6
patsajak
well i need to get the nut out first, would it be able to come out if i took the liner of the trunk?
Old 02-25-2012, 03:30 PM   #7
krappy
Trader Rating: (41)
krappy is an unknown quantity at this point
Feedback Score: 41 reviews
rivnut. easiest solution
krappy is offline   Reply With Quote
Old 02-29-2012, 09:15 AM   #8
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
You might get lucky taking out the third brake light, i honestly forgot how the hatch is since i havent owned a s13 in many years
Old 02-29-2012, 09:19 AM   #9
Darren
Darren's Avatar
Darren is an unknown quantity at this point
you can get it out by taking off the cover that is over the wiper area... then closing the hatch so it rolls down there...
Or.. you can use put a magnet up there and close the hatch and try to grab it.
Rivnuts might not be a good solution because of how shallow they are.
Either way, someone's gonna have to cut out a square, weld a nut to it and weld in the patch to fix that. probably going to have to be a Tig, also due to the space / metal constraints... Hope you're area has a good fabricator around
Might be eaiser (and cheaper) just get a new hatch? Depends on your area...
Hope that helps.
Darren is offline   Reply With Quote
