10-10-2017, 09:18 AM | #1 |
Zerk Fittings on Steering Rack
Looking to do a manual steering rack conversion on my s13, has anyone ever threaded in Zirk fittings in place of the ps lines? Figured it will make it convenient to re pack with grease. Was hoping someone knows what size Zirks to use.
Thanks |
10-10-2017, 10:09 AM | #2 |
Trader Rating: (106)
Feedback Score: 106 reviews
You shouldn't need to re-grease the rack and if you did the steering line ports is NOT where you would want to put the fittings. The entire steering rack is not supposed to be FULL of grease...
10-10-2017, 11:08 AM | #3 |
so there would be no benefit in using zircs and I should just weld those lines shut?
10-10-2017, 12:03 PM | #4 |
ive seen people just weld the fittings shut on FC lines back when I had one (its a popular mod on that chassis), I don't see why this wouldn't work for the S chassis.
10-10-2017, 12:42 PM | #5 |
Trader Rating: (130)
Feedback Score: 130 reviews
my question is, why would you want a manual rack on a 240?
10-10-2017, 12:43 PM | #6 |
Plug or weld up the line ports. MAKE SURE the piston has been removed from the rack gear too!!! It has to be split off the rack gear, like cut in half... If you leave that piston on the rack gear it will result in high steering effort.
10-10-2017, 01:17 PM | #7 |
Trader Rating: (25)
Feedback Score: 25 reviews
Running a manual rack was the best thing I ever did for my driving. Made me a much smoother driver. I originally installed it because I had 3 racks die within a matter of a few months and got tired of replacing them. Had a friend that converted them and did one for free for me. Ended up running it for a year and a half
OP-When mine was converted fittings were welded into those spots. Im sure if you could find fittings that were the right thread pitch, theyd be pricey. That said, I never added grease to mine.
10-10-2017, 02:35 PM | #8 |
not sure if this applies to the 240, but in FC and ae86 land some power racks came with quicker ratios. so people would 'depower' them (just like what reacepar said in post 6) to get the quicker steering ratio for drifting or track usage. you do have to gut it as previously mentioned though, otherwise you just shot yourself in the foot with all the drag in the seals.
I think some people also depower their racks for doing 'nonconventional' swaps. since they make everything under the sun for 240s you could probably figure out how to adapt the PS if you were doing, say, a 5.0 swap. |
10-10-2017, 03:26 PM | #9 | |
Trader Rating: (25)
10-10-2017, 04:21 PM | #10 | ||
10-10-2017, 07:58 PM | #14 |
Trader Rating: (25)
It's great for low powered cars. The faster you go, the harder it is while drifting. I did a kart track with a manual rack and after each lap I would literally be out of breath. After the 2 hour session was over I could barely lift my arms lol. That was the point I decided to go back to power steering, that and because I was planning to boost the ka in the near future.
10-11-2017, 06:08 AM | #15 | |
I've driven a depowered s13 before and imo there is no advantage. ae86 feels great with manual steering, but its also a fairly light car |
10-11-2017, 08:34 AM | #17 |
I did depowered s13 and fc...felt great..more control and positive feedback...I would imiagine they are all very similar...find a youtube video and see whats the same and whats not!
10-11-2017, 09:18 AM | #18 |
based off the comments in this thread it seems like its all personal preference as well as chassis selection and overall setup. i cant imagine having a 18x9-10 wide front wheel without power steering.
10-11-2017, 09:21 AM | #19 |
lol, I am running an 18x10 up front and I want to de power it. Ive been driving it for 2 years with the power steering pump disconnected so it can only get easier from here. I had manual racks on the civics ive owned and personally loved it
10-11-2017, 10:03 AM | #20 |
I would be willing to bet the S13 wasn't de-powered correctly. Removing the lines and draining the fluid isn't enough. You need to cut the piston off the rack gear like I said. S-chasis steering is really pretty numb and doesn't re-center well. It's not terrible, but go drive some M3s and Porsches, it's not that great. Correctly executed a manual steering conversion vastly improves both. S-chasis guys don't do it because they're all drifters. When you're going from lock to lock repeatedly the increased effort is going to be tiring, especially with funny knuckles that screw with the leverage that the steering has on the wheels.
10-11-2017, 10:09 AM | #21 | |
10-11-2017, 01:54 PM | #22 | |
Trader Rating: (25)
10-19-2017, 01:07 PM | #23 |
took it all apart yesterday and what a pain it was! Nissan did not intend on having anyone take this thing apart. The collar on the rack has a factory punch which makes it extremely hard to spin off. Not to mention the size of the pre tensioner nut and the collar nut are so big that you have to use a pipe wrench to get both off. (36mm socket was still too small). Luckily I was able to take off the nut just enough to wedge a screw driver in there and bend the piece that was punched enough to let it spin
10-19-2017, 02:19 PM | #24 | |
