05-25-2009, 01:22 PM | #1 |
s13, sr s14 and turbo 2g eclipse fs/trade
like the title says, i have 2 (possibly 3)cars for sale or trade. i also have a 2007 kawasaki 250 quad i might include for the right deal.
im looking for basicly something really nice and newer. including: 4x4 truck, bike, or car, all offers considered. the 240sx runs and drives great. i want $2500 firm or trade bright red s13: it is a 1992 240sx se 5 speed. just had engine swap done newer s14 ka24de/trans with 75k miles on them, chassis has 200k all new fluids(coolant,10w30 oil,trans. 80w90, rear diff. 80w90) new water pump new thermostat all new gaskets (no leaks at all!!) new blue NGK performance wires new ngk spark plugs new dist. cap new rotor newer s14 injectors s14 fuel pump new exhaust manifold to pipe studs(real bitch to do if they break) exedy clutch tenzo r intake very loud 2 1/2" magnaflow exhaust new cat (for ca smog) lowered about 2" kyb shocks/struts eibach sportline springs 15" black rota rims pioneer head unit sony 6x9's in front sony rear speakers tweeters in both front headrests(you cant see them) amp under pass seat to run 6x9's new black leather shift boot (needs to be installed) newer black carpet all original black panels inside. had brake job done 1 year ago painted all calipers red 1 mo. ago toyo proxes in rear 65% left has sunroof that is removable popup headlights tinted side corner windows some minor problems: i run popup headlight up all the time cause somethimes it takes a little while for one side to pop up. needs front tires(cheap 15"), it also needs the rims balanced(shakes a little at 65-75)ecu was bought online, and had different id code on it, but was out of same year make model. runs great all the time but sometimes the engine light will come on. the eclipse is pretty fast and runs/drives great. no leaks, knocks, ticking,or anything. engine sounds so smooth. black 1995 mitsubishi eclipse 5 speed turbo 155k miles only the year model 1995 has this saught after eprom ecu all work done 8k miles ago new bottom end new headgasket all new gaskets(no leaks at all!!) new pistons/ wrist pins new clevite main bearings new clevite rod bearings balance shafts removed(gains 8 hp) new upgraded non ticking lifters new timing belt kit new oil pump new water pump new thermostat lightweight crank pulley new belts new hoses ngk plugs custom spark plug cover performance accel yellow wires K&N FIPK filter kit venom module hks cams greddy intercooler piping greddy rs blow off valve newer low milage stock t25 turbo(only boosting 11 lbs. ) clutchmasters stage 2 clutch($750 item clutchmasters.com) fidanza short shifter new slave cylninder/ clutch line aftermarket header(not installed) 3" megan downpipe(not installed) tenzo r axleback exhaust clear alteza rear tailights apc white face gauges pioneer headunit just had calipers painted red yesterday new front brakes new tie rod ends new swaybar bushings new lower control arms strut bar in front adjustable springs 18" silver gt rims Zeixes tires may need new tires in next 8k mi. some minor problems: the headliner was sagging so i removed the material($10 fix), the car is originaly from texas and was sponsored, it has sponsor stickers, matching down both doors,pass airbag is kinda peeling at the corners, clear coat is peeling on top portion of car, hood and roof were sanded and were primered black. car still looks great i think. very reliable for a turbo eclipse i have a greenish bluish color 95 240sx w s14 sr20det swap i might consider trading for the right trade. w/ full 3" turboback exhaust,wraped header,new ngk iridiums, new gaskets, new s15 turbo, i havent even put on yet. black 17 inch rims. new tires front/rear. just changed oil. oem nissan oil filter, new dipstick, all oem swap other than that. looks great. like i said i am willing to trade everything listed here for one really nice, and has to be pretty new. truck, car, bike, or multiple items. let me know what you got. i will email pics, until i figure out how to put them on here Last edited by eclipsegsxccca; 05-25-2009 at 02:39 PM.. Reason: not enough info |
05-25-2009, 01:41 PM | #2 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
No email for pics.
Go to Photobucket(or any other free picture uploading site). Upload your pictures(insanely simple). Copy/paste the links onto here. Done. |
for sale, greddy, s13, turbo |
