Old 07-07-2018, 08:17 PM   #1
oLemurs
oLemurs's Avatar
oLemurs is a well-known jackass
strangest overheating issue
before you say use the search tool trust me ive searched every forum out there and cant find a similar issue.
so im having an issue where anytime i take it on the highway i start to overheat. i can drive it around town all day and no issues but as soon as i hit the highway it gets real hot.
i did notice due to a hot ambient temperature it would overheat more quickly (probably doesnt matter but just thought i should say it). if i pull over and wait like not even 5 minutes itll cool down all the way but as soon as i start driving it again.
i can drive it around town all day but i cant go a constant speed without stops. i also beat on the car a little and have no issues.
i check the coolant cap and so far no whiteness. i also bled the system very well for a solid 20-30 minutes with my coolant funnel.
i have a BRAND new ISR Radiator ISR Fan shroud with fans. and before you ask no they are not wired backwards, i have them behind the radiator pulling air.
so far i replaced the thermostat, and looped the heater core line because i thought the kink caused issues. heres some pictures that might help you help me diagnose the issue. water pump doesnt leak or make strange noises but that is on the list of things to be replaced, along with a coolant flush (even though the coolant is not even a year old and has barely any use on it.)
https://imgur.com/gallery/hxPweOo
oLemurs is offline   Reply With Quote
Old 07-08-2018, 08:55 AM   #2
unicoder
unicoder's Avatar
unicoder is an unknown quantity at this point
If you are going to go through the trouble of telling us not to telll you to search. Do us a favor and list all the important things and their results too.
1. Have you confirmed your fans are working correctly?
2. Have you REALLY bled your cooling system to make sure there is no air? For some people, they have a hard time getting the last bit of air out on these cars.
3. Did you install the thermostat correctly? They are directional and you need the jiggle valve positioned at 12 o'clock.
4. When the car warms up, is the upper radiator hose cool or warm? is the bottom hose cool or warm?
5. Have you replaced the radiator cap?
6. Can you see the coolant flowing when you let your car warm up from idle and remove the radiator cap? (it wont move while cold), to confirm the thermostat is opening?
Use all the questions normally asked in the other threads you searched, to give us info in this thread to help out
95 KA-T
unicoder is offline   Reply With Quote
Old 07-08-2018, 09:04 AM   #3
oLemurs
oLemurs's Avatar
yea sorry,
1. they work correctly i shut them off while overheating and it spiked bad. oh yea forgot to mention i have them wired up to a switch on individual relays.
2. ill try to re bleed it and jack up the front end again
3. jiggle valve is directly at the top
4. both of the hoses are very hot
5. i have not but this is the one that came with the radiator. its 1.1 bar
6. i know the thermostat is opening because the same thing happened with my last one and i put the old one in boiling water.
Old 07-08-2018, 01:56 PM   #4
S13project
S13project's Avatar
S13project is on a distinguished road
Is the cap sealing properly with the radiator? Had same thing happen on another car, but with OEM radiator. The ledge the cap sits on was slightly eroded, so when the pressure would rise up it wouldn't hold and thus not cool properly. Never leaked either which puzzled the crap out of me.
S13project is offline   Reply With Quote
Old 07-08-2018, 07:41 PM   #5
oLemurs
oLemurs's Avatar
tbh it looks good, radiator and cap are both new and i just pressure tested it. at 1.1 bar itll hold for a pretty long time but slowly let out just like the whole system
Old 07-09-2018, 04:01 AM   #6
rawgarage
rawgarage's Avatar
Trader Rating: (79)
rawgarage is making a name for him/her selfrawgarage is making a name for him/her selfrawgarage is making a name for him/her self
Feedback Score: 79 reviews
any leaks or overflow overfilling?
"Life isn't Hard, You're just Soft" - www.rawgarage.us
Old 07-09-2018, 08:04 AM   #7
KAT-PWR
KAT-PWR's Avatar
I had something similar, it was a pin hole in a hose under intake manifold. Finally found it. Would only have enough pressure to leak when hot
S13.5 KA-T Build
MRP Manufacturing
IG:240_Trav
Old 07-09-2018, 08:31 AM   #8
KoukiMonsta
KoukiMonsta's Avatar
utilize the return key once in a while, so I can actually read the post.
Then I'll probably try and help.
S13 Build
KoukiMonsta is online now   Reply With Quote
Old 07-09-2018, 10:33 AM   #9
oLemurs
oLemurs's Avatar
fixed the spacing
Old 07-09-2018, 10:35 AM   #10
oLemurs
oLemurs's Avatar
no overflow overfilling BUT when i pressurized the system the pressure would slowly let out, i mean real slow but i think im going to pull the intake manifold and delete all the BS lines under there
Old 07-09-2018, 10:35 AM   #11
oLemurs
oLemurs's Avatar
good idea, im going to be re doing all the hoses under the intake manifold since some of them are still the original ones.
Old 07-09-2018, 10:55 AM   #12
KoukiMonsta
you sure water pump is good? I have seen them where the fins are literally gone from years of corrosion.
S13 Build
Old 07-09-2018, 11:46 AM   #13
oLemurs
oLemurs's Avatar
see thats what i was thinking, but it didnt really make sense to me until you explained it this way
Old 07-09-2018, 12:59 PM   #14
KoukiMonsta
I used to work in one of the big name auto parts stores, I've seen some stuff that is just 'how the fuck did you do this?'
But I'll never forget the waterpump this guy brought in. The fins/blades were paper thin, like tin foil. I mean, was the guy running salt water in the fucking radiator?
I cannot view imgur so idk what that pic is.
what motor you got? SR?
my initial thought, and why I asked if you have actually looked at the pump, is that you aren't flowing enough water.
At higher RPM you generate more heat, and water pump turns faster to compensate. But when you are at higher rpm the engine cant cool quick enough. this makes me think water flow.
Have you flushed the system? old hoses, could have blockage? Fresh new coolant to go with with ur new rad?
S13 Build
Old 07-09-2018, 01:44 PM   #15
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
Define overheat? What temps? Or is this just the stock gauge? How old is the temp sensor?
It kind of sounds like an airflow problem. If I understand, you have beat on it at low speeds and it was fine. As in you've been higher in the RPMs at low speeds, but once you get up to 65+ it starts overheating?
Is there any blockage in front of the radiator, or do you still have an AC condenser.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 07-09-2018, 07:59 PM   #16
oLemurs
oLemurs's Avatar
yea about at 60 itll overheat but the faster i go the quicker it overheats. i did notice after it was a little over 170 and i take it off the road going about 35 itll still overheat just slower. i have no AC condensor but i do have a huge intercooler up front wich is very clean.
Old 07-09-2018, 08:02 PM   #17
oLemurs
oLemurs's Avatar
yea SR20 and i have not looked up the pump internally. and what you said about being low rpm with high heats is EXACTLy what i was thinking. i still have some really old hoses which will be looped when i do the water pump.
Old 07-10-2018, 06:54 AM   #18
KoukiMonsta
a little over 170
Hold the phone.
170 is COLD.
'Define overheat? What temps? Or is this just the stock gauge? How old is the temp sensor? '
S13 Build
Old 07-10-2018, 07:28 AM   #19
KiDyNomiTe
KiDyNomiTe's Avatar
Hold the phone.
170 is COLD.
Ya what? For summer time, especially considering its been the hottest all year that temp is cold. Overheating is around 230.
PROCEED
Grip Gambler
Old 07-10-2018, 08:06 AM   #20
tuzzio
tuzzio's Avatar
tuzzio has much to be proud oftuzzio has much to be proud oftuzzio has much to be proud oftuzzio has much to be proud oftuzzio has much to be proud oftuzzio has much to be proud oftuzzio has much to be proud oftuzzio has much to be proud oftuzzio has much to be proud oftuzzio has much to be proud oftuzzio has much to be proud of
Unless you're talkin 170 celsius...
Old 07-10-2018, 11:33 AM   #21
oLemurs
oLemurs's Avatar
no no i was saying 170 as like when even if it starts overheating at all, it gets up to 200 if i dont let it cool down
Old 07-10-2018, 01:26 PM   #22
KoukiMonsta
some background knowledge for ya, you can find actual science for this shit...here's the concept.
water boils at 212 degrees freedom
water under pressure, such as in a cooling system, boils at some temp above 212
coolant boils at some temp higher than water
therefore - coolant under pressure boils at a temp higher than regular ass water.
under 200 is too cold. 200 is fine. 220 is getting hot. 230 is too hot.
S13 Build
Old 07-10-2018, 02:45 PM   #23
beems240sx
beems240sx's Avatar
beems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant future
Shit my 1J spiked at 250 at the track last hot lap event. My last SR never let it past 230 in fear of warping the head. where do you have your aftermarket temp gauge reading from? is the temp sensor properly grounded with NO teflon?
beems240sx is offline   Reply With Quote
Old 07-11-2018, 08:13 AM   #24
KiDyNomiTe
KiDyNomiTe's Avatar
See how hot it gets, if you hit 230 slow down, and you have a real problem, if it sits around 200 at 70MPH you should be fine.
PROCEED
Grip Gambler
Old 07-11-2018, 10:09 AM   #25
tuzzio
tuzzio's Avatar
If it stays at 200 when its 90* outside...you're doing just fine
Old 07-12-2018, 05:46 AM   #26
oLemurs
oLemurs's Avatar
well it WILL keep going up just very slowly
