Old 01-09-2019, 12:43 PM   #1
nosuitorty
nosuitorty is an unknown quantity at this point
NX Cluster for RB25
I just purchased the NX digital cluster and wanted to know if it can be wired to an RB25? If it can, does it only work with a stock ecu or will it work with a nistune as well?
nosuitorty is offline   Reply With Quote
Old 01-09-2019, 12:46 PM   #2
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Use FSM’s and repin the cluster harness.
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 01-09-2019, 12:49 PM   #3
nosuitorty
FSM is what exactly lol? Having a absent brain day [emoji23][emoji23]
Old 01-09-2019, 12:51 PM   #4
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
full service manual.
jumpman2334 is offline   Reply With Quote
Old 03-01-2019, 03:39 PM   #5
foreverdeath
foreverdeath's Avatar
foreverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the rough
itll will work with a RB25, ive wired one up for a RB25DET NEO before. you will need a tach converter to get tach speed right.http://www.dakotadigital.com/index.c...rod/prd127.htm
the speedo will be correct as long as you have the right color gear on the VSS to match your final drive.
foreverdeath is offline   Reply With Quote
