Old 03-13-2018, 02:01 PM   #1
NismoS13Kings
NismoS13Kings's Avatar
NismoS13Kings is an unknown quantity at this point
Positive terminal wiring
Just picked up this S13 and the previous owner had these 2 wires clamped and connected to the positive terminal. He said he has to unplug the battery or it will drain, so I'm trying to figure out how this wiring originally was to eliminate this issue. Figured id start here with this. Does anyone know what these wires are for and how they originally tie in with the harness? Thanks
NismoS13Kings is offline   Reply With Quote
Old 03-13-2018, 02:19 PM   #2
jedi03
is that body power and if so should go to the main fuse...
Old 03-23-2018, 03:11 PM   #3
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
you might have broken open wire some where that causing battery to drain. Positive wire have red plug connector and 2 plug have terminal inside to plug into it. Those wires help start car.
kennedy8383 is offline   Reply With Quote
